The Easy Wood Tools Full‑Size Easy Finisher™ is a carbide woodturning tool designed for refining curves, smoothing hollows, and producing clean final shapes on large bowls, spindles, table legs, platters, and other substantial projects. As part of the Full‑Size range, it offers maximum leverage and extended reach, making it ideal for finishing work on bigger, heavier workpieces.
Featuring a replaceable round carbide cutter and a sturdy 12.7mm square section bar, the Full‑Size Easy Finisher™ stays flat and stable on the tool rest, giving you predictable control with no sharpening required. Its 406mm American Maple handle provides superior leverage and balance, allowing turners to work comfortably when smoothing wide curves or refining deeper areas.
The Full‑Size Easy Finisher™ is engineered to deliver smooth, flowing cuts that refine the form and prepare it for sanding. It excels at blending curves, shaping hollowed areas, and cleaning up the interior and exterior of large bowls. When the tool is held parallel to the floor at centre height, the square bar keeps the tool steady and greatly reduces the risk of catches or snatches, even when working on wide or heavy blanks. Its combination of weight, reach, and cutter geometry makes it highly effective for controlled finishing on substantial workpieces.
With no sharpening needed, simply rotate the cutter to a fresh edge when dull. Easy Wood Tools’ premium solid carbide lasts many times longer than HSS and is suitable for turning dry or green wood, acrylics, and resin. All Easy Wood Tools are 100% made in the USA.
What you get
Round carbide cutter fitted as standard
Hex key for easy cutter rotation or replacement
406mm American Maple handle with copper ferrule for strength
12.7mm square section bar for maximum stability on the tool rest
Colour‑coded handle for quick identification within the range
Shaft engraved with the carbide cutter reference number
Specifications
Overall length: 622mm
Handle length: 406mm
Bar profile: 12.7mm square
Optional upgrade
Negative rake carbide cutters are available separately and work especially well on acrylics, polyester, and resin, producing a finer, smoother finish on timber when refining shapes and performing final cuts.
Replacement Tip Ci0 (109258)
EAN Barcode 5052511133390
