{"product_id":"easy-wood-tools-full-size-easy-finisher","title":"Easy Wood Tools Full-Size EASY FINISHER™","description":"\u003cp\u003eThe Easy Wood Tools Full‑Size Easy Finisher™ is a carbide woodturning tool designed for refining curves, smoothing hollows, and producing clean final shapes on large bowls, spindles, table legs, platters, and other substantial projects. As part of the Full‑Size range, it offers maximum leverage and extended reach, making it ideal for finishing work on bigger, heavier workpieces.\u003c\/p\u003e\u003cp\u003eFeaturing a replaceable round carbide cutter and a sturdy 12.7mm square section bar, the Full‑Size Easy Finisher™ stays flat and stable on the tool rest, giving you predictable control with no sharpening required. Its 406mm American Maple handle provides superior leverage and balance, allowing turners to work comfortably when smoothing wide curves or refining deeper areas.\u003c\/p\u003e\u003cp\u003eThe Full‑Size Easy Finisher™ is engineered to deliver smooth, flowing cuts that refine the form and prepare it for sanding. It excels at blending curves, shaping hollowed areas, and cleaning up the interior and exterior of large bowls. When the tool is held parallel to the floor at centre height, the square bar keeps the tool steady and greatly reduces the risk of catches or snatches, even when working on wide or heavy blanks. Its combination of weight, reach, and cutter geometry makes it highly effective for controlled finishing on substantial workpieces.\u003c\/p\u003e\u003cp\u003eWith no sharpening needed, simply rotate the cutter to a fresh edge when dull. Easy Wood Tools’ premium solid carbide lasts many times longer than HSS and is suitable for turning dry or green wood, acrylics, and resin. All Easy Wood Tools are 100% made in the USA.\u003c\/p\u003e\u003cp\u003eWhat you get\u003c\/p\u003e\u003cp\u003eRound carbide cutter fitted as standard\u003c\/p\u003e\u003cp\u003eHex key for easy cutter rotation or replacement\u003c\/p\u003e\u003cp\u003e406mm American Maple handle with copper ferrule for strength\u003c\/p\u003e\u003cp\u003e12.7mm square section bar for maximum stability on the tool rest\u003c\/p\u003e\u003cp\u003eColour‑coded handle for quick identification within the range\u003c\/p\u003e\u003cp\u003eShaft engraved with the carbide cutter reference number\u003c\/p\u003e\u003cp\u003eSpecifications\u003c\/p\u003e\u003cp\u003eOverall length: 622mm\u003c\/p\u003e\u003cp\u003eHandle length: 406mm\u003c\/p\u003e\u003cp\u003eBar profile: 12.7mm square\u003c\/p\u003e\u003cp\u003eOptional upgrade\u003c\/p\u003e\u003cp\u003eNegative rake carbide cutters are available separately and work especially well on acrylics, polyester, and resin, producing a finer, smoother finish on timber when refining shapes and performing final cuts.\u003c\/p\u003e","brand":"Easy Wood Tools","offers":[{"title":"Default Title","offer_id":54136155144539,"sku":"109257","price":145.0,"currency_code":"EUR","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0962\/0652\/0667\/files\/109257_xl.jpg?v=1790004670","url":"https:\/\/www.axminstertools.com\/products\/easy-wood-tools-full-size-easy-finisher","provider":"Axminster Tools","version":"1.0","type":"link"}
