{"product_id":"easy-wood-tools-full-size-easy-rougher","title":"Easy Wood Tools Full-Size EASY ROUGHER™","description":"\u003cp\u003eThe Easy Wood Tools Full‑Size Easy Rougher™ is a carbide woodturning tool designed for rapid, controlled material removal when turning large spindles, table legs, big bowls, platters, and other substantial projects.\u003c\/p\u003e\u003cp\u003eAs part of the Full‑Size range, it provides maximum leverage and reach, making it ideal for handling larger, heavier workpieces with confidence and control.\u003c\/p\u003e\u003cp\u003eEquipped with a replaceable square carbide cutter featuring a subtle 100mm corner radius, the Full‑Size Easy Rougher™ delivers smooth, predictable cutting with no sharpening required.\u003c\/p\u003e\u003cp\u003eThe substantial 12.7mm square section bar sits flat and steady on the tool rest, while the 406mm American Maple handle offers greater control during demanding roughing cuts - ideal for professional‑level or large‑scale turning.\u003c\/p\u003e\u003cp\u003eDesigned for heavy stock removal, the Full‑Size Easy Rougher™ removes material quickly, cleanly, and efficiently, helping you establish shape on large blanks with minimal effort.\u003c\/p\u003e\u003cp\u003eWhen used parallel to the floor at centre height, the square bar ensures excellent tool stability and helps virtually eliminate catches and snatches, even on wide or deep workpieces.\u003c\/p\u003e\u003cp\u003eIts geometry and mass make it perfect for tackling large diameter bowls and long spindle work before moving on to a finisher or detailer.\u003c\/p\u003e\u003cp\u003eWith no sharpening needed, simply loosen the retaining screw and rotate the cutter to a fresh edge when dull.\u003c\/p\u003e\u003cp\u003eEasy Wood Tools’ premium solid carbide stays sharp many times longer than HSS and is suitable for turning dry or green wood, acrylics, and resin.\u003c\/p\u003e\u003cp\u003eAll Easy Wood Tools are 100% made in the USA.\u003c\/p\u003e\u003cp\u003eWhat you get\u003c\/p\u003e\u003cp\u003eSquare carbide cutter with slight corner radius (100mm)\u003c\/p\u003e\u003cp\u003eHex key for quick cutter rotation or replacement\u003c\/p\u003e\u003cp\u003e406mm American Maple handle with copper ferrule for strength\u003c\/p\u003e\u003cp\u003e12.7mm square section bar for maximum stability\u003c\/p\u003e\u003cp\u003eColour‑coded handle for quick identification within the range\u003c\/p\u003e\u003cp\u003eShaft engraved with carbide cutter reference number\u003c\/p\u003e\u003cp\u003eSpecifications\u003c\/p\u003e\u003cp\u003eOverall length: 622mm\u003c\/p\u003e\u003cp\u003eHandle length: 406mm\u003c\/p\u003e\u003cp\u003eBar profile: 12.7mm square\u003c\/p\u003e\u003cp\u003eOptional upgrade\u003c\/p\u003e\u003cp\u003eNegative rake carbide cutters are available separately and work especially well on acrylics, polyester, and resin, providing a finer, smoother surface on timber during shaping.\u003c\/p\u003e","brand":"Easy Wood Tools","offers":[{"title":"Default Title","offer_id":54118468813147,"sku":"109249","price":145.0,"currency_code":"EUR","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0962\/0652\/0667\/files\/109249_xl.jpg?v=1789781437","url":"https:\/\/www.axminstertools.com\/products\/easy-wood-tools-full-size-easy-rougher","provider":"Axminster Tools","version":"1.0","type":"link"}
