{"product_id":"easy-wood-tools-full-size-easy-turning-set-3-piece","title":"Easy Wood Tools Full-Size Easy Turning™ Set 3-Piece","description":"\u003cp\u003eThe Easy Wood Tools Full‑Size Easy Turning™ Set 3‑Piece provides a complete solution for turning larger projects, including spindles, table legs, and large bowls, combining strength, reach, and control in one versatile set.\u003c\/p\u003e\u003cp\u003eIt includes the Full‑Size Easy Rougher™, Easy Finisher™, and Easy Detailer™, giving you everything needed to move from rapid material removal through shaping to fine detailing on bigger workpieces.\u003c\/p\u003e\u003cp\u003eEach tool features a replaceable carbide cutter and a robust 12.7mm square section bar that sits flat and steady on the tool rest, making them easy to control and highly predictable in use.\u003c\/p\u003e\u003cp\u003eThe longer 406mm American Maple handles provide added leverage and balance, giving you greater control when working on larger blanks or deeper forms.\u003c\/p\u003e\u003cp\u003eWith no sharpening required, you can focus entirely on turning, rather than maintaining tools.\u003c\/p\u003e\u003cp\u003eWorking together as a complete system, each tool plays a distinct role. The Easy Rougher™ uses a square cutter to remove material quickly and efficiently, allowing you to establish shape with ease. The Easy Finisher™, fitted with a round cutter, refines curves, shapes hollows, and smooths surfaces ready for final finishing. The Easy Detailer™, with its diamond‑shaped cutter, creates crisp beads, coves, and fine decorative features.\u003c\/p\u003e\u003cp\u003eWhen used parallel to the floor at centre height, the square bar keeps each tool stable on the rest, helping to minimise catches and snatches. This stability, combined with the added leverage of the full‑size handles, makes the set particularly effective when working on larger and heavier workpieces.\u003c\/p\u003e\u003cp\u003eEasy Wood Tools’ long‑lasting carbide cutters hold an edge many times longer than HSS and are suitable for dry or green wood, as well as acrylics. With no sharpening needed, maintenance is simple — when the edge dulls, just loosen the fixing screw and rotate or replace the cutter.\u003c\/p\u003e\u003cp\u003eThe shaft is engraved with the corresponding carbide cutter reference number for easy identification.\u003c\/p\u003e\u003cp\u003eAll Easy Wood Tools are 100% made in the USA.\u003c\/p\u003e\u003cp\u003eSpecifications\u003c\/p\u003e\u003cp\u003eSet includes: Full‑Size Easy Rougher™, Easy Finisher™, Easy Detailer™\u003c\/p\u003e\u003cp\u003eCutter types: Square, round, and diamond carbide cutters\u003c\/p\u003e\u003cp\u003eBar profile: 12.7mm square section for stability on the tool rest\u003c\/p\u003e\u003cp\u003eHandle length: 406mm\u003c\/p\u003e\u003cp\u003eOverall length: 622mm\u003c\/p\u003e\u003cp\u003eHandles: American Maple with copper ferrules\u003c\/p\u003e\u003cp\u003eUse: Suitable for dry or green wood and acrylics\u003c\/p\u003e\u003cp\u003eNegative rake carbide cutters are available separately and work particularly well on acrylics, polyester, and resin, while also helping to produce a finer, smoother finish on timber during shaping and final cuts.\u003c\/p\u003e","brand":"Easy Wood Tools","offers":[{"title":"Default Title","offer_id":54136155537755,"sku":"109209","price":390.0,"currency_code":"EUR","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0962\/0652\/0667\/files\/109209_xl.jpg?v=1790004689","url":"https:\/\/www.axminstertools.com\/products\/easy-wood-tools-full-size-easy-turning-set-3-piece","provider":"Axminster Tools","version":"1.0","type":"link"}
