{"product_id":"easy-wood-tools-micro-easy-detailer","title":"Easy Wood Tools Micro EASY DETAILER™","description":"\u003cp\u003eThe Easy Wood Tools Micro Easy Detailer™ is a carbide woodturning tool designed for creating fine details, small coves, delicate beads, and precise decorative features on pens, bottle stoppers, ornaments, and miniature projects.\u003c\/p\u003e\u003cp\u003eAs part of the Micro range, it is purpose‑built for precision work in tight areas, where accuracy and control are essential.\u003c\/p\u003e\u003cp\u003eFitted with a diamond‑shaped replaceable carbide cutter, the Micro Easy Detailer™ allows you to cut crisp detail lines with ease. Its compact, lightweight design and flat‑profile bar ensure the tool sits securely on the rest, making it easy to control without needing to apply complex angles or techniques.\u003c\/p\u003e\u003cp\u003eThe Micro Easy Detailer™ is designed to deliver clean, accurate detailing cuts, allowing you to add definition and decoration to your work with confidence. It excels at refining small features and working in confined areas where larger tools are harder to control.\u003c\/p\u003e\u003cp\u003eWhen used parallel to the floor at centre height, the flat bar design keeps the tool stable, helping reduce catches and supporting controlled, precise cuts on small‑diameter workpieces.\u003c\/p\u003e\u003cp\u003eEasy Wood Tools’ long‑lasting carbide cutters hold an edge many times longer than HSS and are suitable for dry or green wood, as well as acrylics. With no sharpening needed, maintenance is simple — when the edge dulls, just loosen the fixing screw and rotate or replace the cutter.\u003c\/p\u003e\u003cp\u003eThe shaft is engraved with the corresponding carbide cutter reference number for easy identification.\u003c\/p\u003e\u003cp\u003eAll Easy Wood Tools are 100% made in the USA.\u003c\/p\u003e\u003cp\u003eSpecifications\u003c\/p\u003e\u003cp\u003eTool type: Micro carbide detailing tool\u003c\/p\u003e\u003cp\u003eCutter type: Diamond‑shaped carbide cutter\u003c\/p\u003e\u003cp\u003eRange: Micro (compact for ultra‑fine work)\u003c\/p\u003e\u003cp\u003eBar profile: Flat section for stability on the tool rest\u003c\/p\u003e\u003cp\u003eHandle: Hardwood with copper ferrule\u003c\/p\u003e\u003cp\u003eNegative rake carbide cutters are available separately and are particularly effective on acrylics, polyester, and resin, helping to achieve a smoother finish and increased control on delicate materials.\u003c\/p\u003e","brand":"Easy Wood Tools","offers":[{"title":"Default Title","offer_id":54136155701595,"sku":"109202","price":98.0,"currency_code":"EUR","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0962\/0652\/0667\/files\/109202_xl.jpg?v=1790004698","url":"https:\/\/www.axminstertools.com\/products\/easy-wood-tools-micro-easy-detailer","provider":"Axminster Tools","version":"1.0","type":"link"}
