The Easy Wood Tools Micro Easy Rougher™ is a carbide woodturning tool designed for controlled material removal on smaller workpieces, making it ideal for shaping pens, bottle stoppers, small spindles, and miniature projects. As part of the Micro range, it offers precise control in tight spaces where larger tools would be difficult to handle.
Fitted with a square replaceable carbide cutter, the Micro Easy Rougher™ allows you to remove material cleanly while maintaining excellent control. The compact tool size combined with a flat‑profile bar ensures the tool sits securely on the rest, enabling smooth cuts without needing to manage complex tool angles or sharpening routines.
Designed for smaller‑scale turning, the Micro Easy Rougher™ removes material quickly, cleanly, and predictably, allowing you to establish shape while maintaining control over delicate workpieces.
When used parallel to the floor at centre height, the flat bar design keeps the tool stable on the rest, helping to reduce the likelihood of catches and making it particularly suitable for beginners or detailed work where precision is essential.
Easy Wood Tools’ long‑lasting carbide cutters hold an edge many times longer than HSS and are suitable for dry or green wood, as well as acrylics. With no sharpening needed, maintenance is simple — when the edge dulls, just loosen the fixing screw and rotate or replace the cutter.
The shaft is engraved with the corresponding carbide cutter reference number for easy identification.
Specifications
Tool type: Micro carbide roughing tool
Cutter type: Square carbide cutter
Range: Micro (compact size for small work)
Bar profile: Flat section for stability on the tool rest
Handle: Hardwood with copper ferrule
Negative rake carbide cutters are available separately and work particularly well on acrylics, polyester, and resin, helping to produce a smoother finish and increased control on delicate materials.
