{"product_id":"easy-wood-tools-mid-size-easy-detailer","title":"Easy Wood Tools Mid-Size EASY DETAILER™","description":"\u003cp\u003eThe Easy Wood Tools Mid‑Size Easy Detailer™ is a carbide woodturning tool designed for creating small coves, beads, and fine decorative details when turning bowls, platters, boxes, spindles, and other projects.\u003c\/p\u003e\u003cp\u003eWith increased reach compared to the Easy Start range, it is a versatile go‑to detailing tool for turners working on larger workpieces while still requiring precise, controlled cuts.\u003c\/p\u003e\u003cp\u003eFeaturing a replaceable diamond‑shaped carbide cutter and a 9.5mm square section bar that sits flat on the tool rest, the Mid‑Size Easy Detailer™ delivers excellent stability and easy control with no sharpening required.\u003c\/p\u003e\u003cp\u003eThe longer handle provides improved leverage and balance, making it well suited to bowl and faceplate work, while remaining intuitive and predictable for turners progressing beyond smaller tools.\u003c\/p\u003e\u003cp\u003eDesigned for controlled, accurate cutting, the Mid‑Size Easy Detailer™ allows you to create fine details cleanly and consistently, even on larger blanks.\u003c\/p\u003e\u003cp\u003eThe square section bar ensures the tool remains flat and steady on the tool rest, and when used parallel to the floor at centre height, the risk of catches and snatches is virtually eliminated, supporting confident detail work at the lathe.\u003c\/p\u003e\u003cp\u003eWith no sharpening needed, maintenance is simple - when the edge becomes dull, just loosen the fixing screw and rotate the cutter to a fresh edge.\u003c\/p\u003e\u003cp\u003eEasy Wood Tools’ long‑lasting carbide cutters keep an edge many times longer than HSS and are suitable for turning dry or green wood, as well as acrylics.\u003c\/p\u003e\u003cp\u003eThe shaft is engraved with the corresponding carbide cutter reference number for easy identification.\u003c\/p\u003e\u003cp\u003eAll Easy Wood Tools are 100% made in the USA.\u003c\/p\u003e\u003cp\u003eWhat you get\u003c\/p\u003e\u003cp\u003eDiamond‑shaped carbide cutter fitted as standard\u003c\/p\u003e\u003cp\u003eHex key for easy cutter rotation or replacement\u003c\/p\u003e\u003cp\u003e350mm long American maple handle with copper ferrule for added strength\u003c\/p\u003e\u003cp\u003eColour‑coded handle for easy identification within the Easy Wood Tools range\u003c\/p\u003e\u003cp\u003eSpecifications\u003c\/p\u003e\u003cp\u003eOverall length: 533mm\u003c\/p\u003e\u003cp\u003eBar profile: 9.5mm square section\u003c\/p\u003e\u003cp\u003eOptional upgrade\u003c\/p\u003e\u003cp\u003eNegative rake carbide cutters are available separately and work particularly well on acrylics, polyester, and resin materials, while also producing a finer, smoother finish on timber as skills develop.\u003c\/p\u003e","brand":"Easy Wood Tools","offers":[{"title":"Default Title","offer_id":54136156029275,"sku":"109261","price":130.0,"currency_code":"EUR","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0962\/0652\/0667\/files\/109261_xl.jpg?v=1790004724","url":"https:\/\/www.axminstertools.com\/products\/easy-wood-tools-mid-size-easy-detailer","provider":"Axminster Tools","version":"1.0","type":"link"}
