{"product_id":"easy-wood-tools-mid-size-easy-finisher","title":"Easy Wood Tools Mid-Size EASY FINISHER™","description":"\u003cp\u003eThe Easy Wood Tools Mid‑size Easy Finisher™ is a carbide woodturning tool designed for making coves, hollows, sweeping curves, and final shaping on bowls, platters, boxes, spindles, and other projects.\u003c\/p\u003e\u003cp\u003eOffering greater reach and versatility than the Easy Start range, it’s the perfect go‑to finishing tool for turners working on medium to larger workpieces.\u003c\/p\u003e\u003cp\u003eFeaturing a replaceable round carbide cutter and a 9.5mm square section bar that sits flat on the tool rest, the Mid‑size Easy Finisher™ delivers excellent stability and easy control with no sharpening required.\u003c\/p\u003e\u003cp\u003eThe extended 350mm American maple handle provides increased leverage and balance, making it ideal for smoothing forms and refining curves on deeper or broader pieces.\u003c\/p\u003e\u003cp\u003eDesigned for smooth, flowing cuts, the Mid‑size Easy Finisher™ excels at cleanly refining shapes, hollow forms, and gentle curves.\u003c\/p\u003e\u003cp\u003eWith the tool held parallel to the floor at centre height, the square bar keeps the tool steady on the rest, helping to virtually eliminate catches and snatches, making finishing cuts predictable and confidence‑building.\u003c\/p\u003e\u003cp\u003eWith no sharpening required, simply loosen the fixing screw and rotate the cutter to a fresh edge when dull.\u003c\/p\u003e\u003cp\u003eEasy Wood Tools’ long‑lasting carbide holds an edge many times longer than HSS and works effectively on dry or green wood, acrylics, and resin.\u003c\/p\u003e\u003cp\u003eEach shaft is engraved with its carbide cutter reference number for easy identification.\u003c\/p\u003e\u003cp\u003eAll Easy Wood Tools are 100% made in the USA.\u003c\/p\u003e\u003cp\u003eWhat you get\u003c\/p\u003e\u003cp\u003eRound carbide cutter fitted as standard\u003c\/p\u003e\u003cp\u003eHex key for quick cutter rotation or replacement\u003c\/p\u003e\u003cp\u003e350mm American maple handle with copper ferrule for strength\u003c\/p\u003e\u003cp\u003eColour‑coded handle for easy identification across the range\u003c\/p\u003e\u003cp\u003eSpecifications\u003c\/p\u003e\u003cp\u003eOverall length: 533mm\u003c\/p\u003e\u003cp\u003eBar profile: 9.5mm square section\u003c\/p\u003e\u003cp\u003eOptional upgrade\u003c\/p\u003e\u003cp\u003eNegative rake carbide cutters are available separately and work particularly well on acrylics, polyester, and resin materials, producing a finer, smoother finish on timber for higher‑quality shaping and surface refinement.\u003c\/p\u003e","brand":"Easy Wood Tools","offers":[{"title":"Default Title","offer_id":54118468223323,"sku":"109311","price":130.0,"currency_code":"EUR","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0962\/0652\/0667\/files\/109311_xl.jpg?v=1789781404","url":"https:\/\/www.axminstertools.com\/products\/easy-wood-tools-mid-size-easy-finisher","provider":"Axminster Tools","version":"1.0","type":"link"}
