{"product_id":"easy-wood-tools-mid-size-easy-hollower-1","title":"Easy Wood Tools Mid-Size EASY HOLLOWER™ #1","description":"\u003cp\u003eThe Easy Wood Tools Mid‑size Easy Hollower™ #1 is a carbide woodturning tool designed for removing the bulk of waste material from inside hollow forms and from the centre of medium to large bowls.\u003c\/p\u003e\u003cp\u003eAs the first tool in the 1‑2‑3 hollowing system, Hollower #1 provides controlled access to the interior of a form, making the early stages of hollowing safer, faster, and more predictable.\u003c\/p\u003e\u003cp\u003eEquipped with a solid carbide cutting tip and a 12.7mm square section shaft, the Mid‑size Easy Hollower™ #1 sits flat and secure on the tool rest, giving excellent stability and easy control with no sharpening required.\u003c\/p\u003e\u003cp\u003eThe 355mm American maple handle provides confident leverage during waste‑removal cuts, allowing turners to deepen forms safely before switching to Hollower #2 or #3 for refinement.\u003c\/p\u003e\u003cp\u003eHollower #1 is optimised for efficient interior waste removal on bowls and hollow forms.\u003c\/p\u003e\u003cp\u003eWith the tool held parallel to the floor at centre height, the square shaft keeps it flat on the rest, helping to minimise catches and snatches while working inside unseen cavities.\u003c\/p\u003e\u003cp\u003eIts geometry gives clear, predictable cutting action - ideal for initial hollowing before moving on to shaping and smoothing tools.\u003c\/p\u003e\u003cp\u003eWith no sharpening needed, simply loosen the fixing screw and rotate the cutter to expose a fresh edge when it dulls.\u003c\/p\u003e\u003cp\u003eEasy Wood Tools’ long‑lasting carbide holds an edge many times longer than HSS and performs reliably on dry or green wood and acrylics.\u003c\/p\u003e\u003cp\u003eAll Easy Wood Tools are 100% made in the USA.\u003c\/p\u003e\u003cp\u003eWhat you get\u003c\/p\u003e\u003cp\u003eSolid carbide cutter fitted as standard\u003c\/p\u003e\u003cp\u003e355mm American maple handle with copper ferrule for strength\u003c\/p\u003e\u003cp\u003e12.7mm square section shaft for maximum stability on the rest\u003c\/p\u003e\u003cp\u003eColour‑coded handle for quick identification within the hollowing system\u003c\/p\u003e\u003cp\u003eEngraved carbide cutter reference number on the shaft\u003c\/p\u003e\u003cp\u003eSpecifications\u003c\/p\u003e\u003cp\u003eOverall length: 572mm\u003c\/p\u003e\u003cp\u003eHandle length: 355mm\u003c\/p\u003e\u003cp\u003eShaft profile: 12.7mm square\u003c\/p\u003e\u003cp\u003eOptional upgrade\u003c\/p\u003e\u003cp\u003eNegative rake carbide cutters are available separately and work especially well on acrylics, polyester, and resin materials, while also producing a finer, smoother finish on timber as hollowing progresses.\u003c\/p\u003e","brand":"Easy Wood Tools","offers":[{"title":"Default Title","offer_id":54118468288859,"sku":"109260","price":150.0,"currency_code":"EUR","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0962\/0652\/0667\/files\/109260_xl.jpg?v=1789781412","url":"https:\/\/www.axminstertools.com\/products\/easy-wood-tools-mid-size-easy-hollower-1","provider":"Axminster Tools","version":"1.0","type":"link"}
