{"product_id":"easy-wood-tools-mid-size-easy-hollower-2","title":"Easy Wood Tools Mid-Size EASY HOLLOWER™ #2","description":"\u003cp\u003eThe Easy Wood Tools Mid‑Size Easy Hollower™ #2 is a carbide woodturning tool designed for the mid‑stage shaping of hollow forms and the interior of medium to large bowls.\u003c\/p\u003e\u003cp\u003eAs the second tool in the Hollowing 1‑2‑3 system, Hollower #2 reaches deeper into the form and begins refining the interior shape after the bulk waste has been removed by Hollower #1.\u003c\/p\u003e\u003cp\u003eFeaturing a solid carbide cutter and a 12.7mm square section shaft, the Mid‑Size Easy Hollower™ #2 sits flat and steady on the tool rest, offering excellent stability and easy control with no sharpening required.\u003c\/p\u003e\u003cp\u003eThe longer 355mm American Maple handle provides secure leverage for deeper cuts, while the tool’s geometry allows smooth shaping inside areas that are no longer directly visible.\u003c\/p\u003e\u003cp\u003eHollower #2 is engineered for controlled interior shaping, improving transitions, smoothing surfaces, and following the developing contour of the form.\u003c\/p\u003e\u003cp\u003eWhen held parallel to the floor at centre height, the square shaft keeps the tool stable on the rest, helping to minimise catches and snatches as you hollow deeper inside the vessel.\u003c\/p\u003e\u003cp\u003eIt provides a balanced combination of reach, control, and refinement before moving on to Hollower #3 for final finishing.\u003c\/p\u003e\u003cp\u003eWith no sharpening required, simply loosen the fixing screw and rotate the cutter to expose a fresh edge when dull.\u003c\/p\u003e\u003cp\u003eEasy Wood Tools’ long‑lasting carbide cutters stay sharp many times longer than HSS and perform reliably on dry or green wood and acrylics.\u003c\/p\u003e\u003cp\u003eAll Easy Wood Tools are 100% made in the USA.\u003c\/p\u003e\u003cp\u003eWhat you get\u003c\/p\u003e\u003cp\u003eSolid carbide cutter fitted as standard\u003c\/p\u003e\u003cp\u003e355mm American Maple handle with copper ferrule for strength\u003c\/p\u003e\u003cp\u003e12.7mm square section shaft for excellent stability\u003c\/p\u003e\u003cp\u003eColour‑coded handle for quick identification within the hollowing system\u003c\/p\u003e\u003cp\u003eEngraved carbide cutter reference number on the shaft\u003c\/p\u003e\u003cp\u003eSpecifications\u003c\/p\u003e\u003cp\u003eOverall length: 572mm\u003c\/p\u003e\u003cp\u003eHandle length: 355mm\u003c\/p\u003e\u003cp\u003eShaft profile: 12.7mm square\u003c\/p\u003e\u003cp\u003eOptional upgrade\u003c\/p\u003e\u003cp\u003eNegative rake carbide cutters are available separately and work particularly well on acrylics, polyester, and resin, producing a smoother, finer finish as hollowing progresses.\u003c\/p\u003e","brand":"Easy Wood Tools","offers":[{"title":"Default Title","offer_id":54118468485467,"sku":"109314","price":165.0,"currency_code":"EUR","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0962\/0652\/0667\/files\/109314_xl.jpg?v=1789781420","url":"https:\/\/www.axminstertools.com\/products\/easy-wood-tools-mid-size-easy-hollower-2","provider":"Axminster Tools","version":"1.0","type":"link"}
