{"product_id":"easy-wood-tools-mid-size-easy-hollower-3","title":"Easy Wood Tools Mid-Size EASY HOLLOWER™ #3","description":"\u003cp\u003eThe Easy Wood Tools Mid‑Size Easy Hollower™ #3 is a carbide woodturning tool designed for final interior shaping and deep‑reach hollowing inside hollow forms and medium to large bowls.\u003c\/p\u003e\u003cp\u003eAs the third tool in the Hollowing 1‑2‑3 system, Hollower #3 reaches deep, unseen cavities, allowing you to refine the final internal surface once Hollower #1 and #2 have established the interior shape.\u003c\/p\u003e\u003cp\u003eFeaturing a solid carbide cutting tip and a 12.7mm square section shaft, the Mid‑Size Easy Hollower™ #3 sits flat and stable on your tool rest, delivering excellent control with no sharpening required.\u003c\/p\u003e\u003cp\u003eThe longer 355mm American Maple handle offers added leverage for deep interior cuts, while the tool’s cutter orientation and reach provide safe, predictable cutting inside areas where visibility is limited.\u003c\/p\u003e\u003cp\u003eHollower #3 is engineered for deep hollowing and final refinement, allowing you to smooth and finish the interior walls of hollow forms with precision.\u003c\/p\u003e\u003cp\u003eUsed parallel to the floor at centre height, the square shaft keeps the tool steady on the rest, helping to minimise catches and snatches, especially when working deep inside closed forms.\u003c\/p\u003e\u003cp\u003eIt provides the reach and finesse needed for the last stage of hollowing, before sanding or final surface work.\u003c\/p\u003e\u003cp\u003eWith no sharpening required, simply loosen the fixing screw and rotate the cutter to a fresh edge when it eventually dulls.\u003c\/p\u003e\u003cp\u003eEasy Wood Tools’ premium carbide lasts many times longer than HSS and can be used on dry or green wood and acrylics.\u003c\/p\u003e\u003cp\u003eAll Easy Wood Tools are 100% made in the USA.\u003c\/p\u003e\u003cp\u003eWhat you get\u003c\/p\u003e\u003cp\u003eSolid carbide cutter fitted as standard\u003c\/p\u003e\u003cp\u003e355mm American Maple handle with copper ferrule for strength\u003c\/p\u003e\u003cp\u003e12.7mm square section shaft for maximum stability on the rest\u003c\/p\u003e\u003cp\u003eColour‑coded handle for quick identification within the 1‑2‑3 system\u003c\/p\u003e\u003cp\u003eEngraved carbide cutter reference number on the shaft\u003c\/p\u003e\u003cp\u003eSpecifications\u003c\/p\u003e\u003cp\u003eOverall length: 572mm\u003c\/p\u003e\u003cp\u003eHandle length: 355mm\u003c\/p\u003e\u003cp\u003eShaft profile: 12.7mm square\u003c\/p\u003e\u003cp\u003eOptional upgrade\u003c\/p\u003e\u003cp\u003eNegative rake carbide cutters are available separately and work especially well on acrylics, polyester, and resin, while delivering a finer, smoother finish on timber during deep interior shaping.\u003c\/p\u003e","brand":"Easy Wood Tools","offers":[{"title":"Default Title","offer_id":54118468583771,"sku":"109315","price":165.0,"currency_code":"EUR","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0962\/0652\/0667\/files\/109315_xl.jpg?v=1789781429","url":"https:\/\/www.axminstertools.com\/products\/easy-wood-tools-mid-size-easy-hollower-3","provider":"Axminster Tools","version":"1.0","type":"link"}
