{"product_id":"easy-wood-tools-mid-size-easy-rougher","title":"Easy Wood Tools Mid-Size EASY ROUGHER™","description":"\u003cp\u003eThe Mid‑Size Easy Rougher™ is a carbide woodturning tool designed for rapid, controlled material removal when turning bowls, platters, boxes, spindles, and larger projects.\u003c\/p\u003e\u003cp\u003eOffering increased reach and versatility over the Easy Start range, it is a reliable go‑to tool for turners looking to tackle a broader range of work with confidence.\u003c\/p\u003e\u003cp\u003eFeaturing a replaceable carbide cutter and a 9.5mm square section bar that sits flat on the tool rest, the Mid‑Size Easy Rougher delivers excellent stability and easy control with no sharpening required.\u003c\/p\u003e\u003cp\u003eThe longer handle provides improved leverage and comfort, making it ideal for bowl and faceplate turning, while remaining intuitive and predictable for turners transitioning from smaller tools.\u003c\/p\u003e\u003cp\u003eThe Mid‑Size Easy Rougher removes material quickly, cleanly and efficiently, helping establish shape with minimal effort on larger blanks.\u003c\/p\u003e\u003cp\u003eThe square section bar ensures the tool remains flat and steady on the tool rest, and when used parallel to the floor at centre height, the risk of catches and snatches is virtually eliminated, supporting smooth, controlled roughing cuts.\u003c\/p\u003e\u003cp\u003eWith no sharpening needed, maintenance is simple - when the edge becomes dull, just loosen the fixing screw and rotate the cutter to a fresh edge.\u003c\/p\u003e\u003cp\u003eEasy Wood Tools’ long‑lasting carbide cutters keep an edge many times longer than HSS and are suitable for turning dry or green wood, as well as acrylics.\u003c\/p\u003e\u003cp\u003eThe shaft is engraved with the corresponding carbide cutter reference number for easy identification.\u003c\/p\u003e\u003cp\u003eAll Easy Wood Tools are 100% made in the USA.\u003c\/p\u003e\u003cp\u003eWhat you get\u003c\/p\u003e\u003cp\u003eSquare carbide cutter fitted as standard\u003c\/p\u003e\u003cp\u003eHex key for easy cutter rotation or replacement\u003c\/p\u003e\u003cp\u003e350mm American maple handle with copper ferrule for added strength\u003c\/p\u003e\u003cp\u003eColour‑coded handle for easy identification within the Easy Wood Tools range\u003c\/p\u003e\u003cp\u003eSpecifications\u003c\/p\u003e\u003cp\u003eOverall length: 533mm\u003c\/p\u003e\u003cp\u003eBar profile: 9.5mm square section\u003c\/p\u003e\u003cp\u003eOptional upgrade\u003c\/p\u003e\u003cp\u003eNegative rake carbide cutters are available separately and work particularly well on acrylics, polyester, and resin materials, while also producing a finer, smoother finish on timber as skills develop.\u003c\/p\u003e","brand":"Easy Wood Tools","offers":[{"title":"Default Title","offer_id":54136158060891,"sku":"109253","price":125.0,"currency_code":"EUR","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0962\/0652\/0667\/files\/109253_xl.jpg?v=1790004733","url":"https:\/\/www.axminstertools.com\/products\/easy-wood-tools-mid-size-easy-rougher","provider":"Axminster Tools","version":"1.0","type":"link"}
