The Easy Wood Tools Mid‑Size Easy Turning™ Set 3‑Piece provides a complete solution for general woodturning, combining the three essential tools needed for shaping, refining, and detailing across a wide range of projects. Including the Mid‑Size Easy Rougher™, Easy Finisher™, and Easy Detailer™, this set is ideal for working on bowls, platters, boxes, spindles, and other everyday turning tasks.
Each tool in the set features a replaceable carbide cutter and a 9.5mm square section bar that sits flat and steady on the tool rest, making them intuitive and easy to control.
The Mid‑Size range offers the perfect balance between reach and handling, providing enough leverage for larger work while remaining precise and comfortable to use.
With no sharpening required, it simplifies the turning process and allows you to focus on technique rather than tool maintenance.
Working together as a complete system, the three tools guide you through the full turning process. The Rougher™ quickly removes material to establish shape, the Finisher™ refines curves and smooths surfaces, and the Detailer™ adds crisp definition and decorative features.
When used parallel to the floor at centre height, the square section bar keeps each tool stable on the rest, helping to reduce catches and deliver predictable, controlled cuts. This makes the set equally suitable for those developing their skills and experienced turners working on a variety of projects.
Easy Wood Tools’ long‑lasting carbide cutters hold an edge many times longer than HSS and are suitable for dry or green wood, as well as acrylics. With no sharpening needed, maintenance is simple — when the edge dulls, just loosen the fixing screw and rotate or replace the cutter.
The shaft is engraved with the corresponding carbide cutter reference number for easy identification.
Specifications
Set includes: Mid‑Size Easy Rougher™, Easy Finisher™, Easy Detailer™
Cutter types: Square, round, and diamond carbide cutters
Range: Mid‑Size (versatile tools for everyday turning)
Bar profile: 9.5mm square section for stability on the tool rest
Handles: American Maple with copper ferrules
Overall length: 533mm.
Negative rake carbide cutters are available separately and are particularly effective on acrylics, polyester, and resin, helping to produce a smoother finish and improved control on more delicate or challenging materials.
EAN Barcode 5052511133475
