{"product_id":"easy-wood-tools-mid-size-micro-easy-detailer","title":"Easy Wood Tools Mid-Size Micro EASY DETAILER™","description":"\u003cp\u003eThe Easy Wood Tools Mid‑size Micro Easy Detailer™ is a carbide woodturning tool designed for creating small coves, delicate beads, and ultra‑fine decorative details on bowls, platters, boxes, spindles, and other projects.\u003c\/p\u003e\u003cp\u003eOffering greater reach and stability than the micro range, but finer precision than the standard Mid‑size Detailer, it is the ideal go‑to tool for intricate finishing work on larger workpieces.\u003c\/p\u003e\u003cp\u003eEquipped with a replaceable carbide cutter and a 9.5mm square section bar that sits flat on the tool rest, the Mid‑size Micro Easy Detailer™ delivers exceptional stability and easy, predictable control with no sharpening required.\u003c\/p\u003e\u003cp\u003eThe extended 350mm American maple handle gives added leverage and balance, making delicate cuts feel safer and more controlled - even on deeper or larger forms.\u003c\/p\u003e\u003cp\u003ePurpose‑built for intricate detail work, this tool excels at producing clean, consistent ultra‑fine details with minimal effort.\u003c\/p\u003e\u003cp\u003eWith the tool held parallel to the floor at centre height, the square bar keeps the tool flat on the rest, helping to virtually eliminate catches and snatches - ideal for delicate finishing cuts on both spindles and faceplate work.\u003c\/p\u003e\u003cp\u003eWith no sharpening needed, simply loosen the fixing screw and rotate the cutter to a fresh edge when dull.\u003c\/p\u003e\u003cp\u003eEasy Wood Tools’ long‑lasting carbide holds an edge many times longer than HSS and can be used on dry or green wood, acrylics, and resin.\u003c\/p\u003e\u003cp\u003eEach shaft is engraved with its carbide cutter reference number for quick identification.\u003c\/p\u003e\u003cp\u003eAll Easy Wood Tools are 100% made in the USA.\u003c\/p\u003e\u003cp\u003eWhat you get\u003c\/p\u003e\u003cp\u003eCarbide cutter optimised for ultra‑fine detail\u003c\/p\u003e\u003cp\u003eHex key for quick cutter rotation or replacement\u003c\/p\u003e\u003cp\u003e350mm long American maple handle with copper ferrule for strength\u003c\/p\u003e\u003cp\u003eColour‑coded handle for easy identification across the range\u003c\/p\u003e\u003cp\u003eSpecifications\u003c\/p\u003e\u003cp\u003eOverall length: 533mm\u003c\/p\u003e\u003cp\u003eBar profile: 9.5mm square section\u003c\/p\u003e\u003cp\u003eOptional upgrade\u003c\/p\u003e\u003cp\u003eNegative rake carbide cutters are available separately and work especially well on acrylics, polyester, and resin materials, producing a smoother, finer finish on timber as skills develop.\u003c\/p\u003e","brand":"Easy Wood Tools","offers":[{"title":"Default Title","offer_id":54136158978395,"sku":"109280","price":135.0,"currency_code":"EUR","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0962\/0652\/0667\/files\/109280_xl.jpg?v=1790004752","url":"https:\/\/www.axminstertools.com\/products\/easy-wood-tools-mid-size-micro-easy-detailer","provider":"Axminster Tools","version":"1.0","type":"link"}
