{"product_id":"easy-wood-tools-mini-easy-detailer","title":"Easy Wood Tools Mini EASY DETAILER™","description":"\u003cp\u003eThe Easy Wood Tools Mini Easy Detailer™ is a carbide woodturning tool designed for creating fine details, small coves, beads, and precise decorative features on small to medium projects, including bowls, spindles, and general craft work. As part of the Mini range, it provides the control needed for detailed work while offering more stability than Micro tools.\u003c\/p\u003e\u003cp\u003eFitted with a diamond‑shaped replaceable carbide cutter, the Mini Easy Detailer™ allows you to create crisp, defined details with minimal effort.\u003c\/p\u003e\u003cp\u003eIts compact yet more substantial build improves control compared to Micro tools, while the flat‑profile bar sits securely on the tool rest, making it easy to use without needing to master complex tool angles or sharpening techniques.\u003c\/p\u003e\u003cp\u003eThe Mini Easy Detailer™ delivers clean, accurate detailing cuts, making it ideal for adding definition and decorative elements to your work. It excels at shaping beads, cutting coves, and refining intricate features on smaller or moderately sized pieces.\u003c\/p\u003e\u003cp\u003eWhen used parallel to the floor at centre height, the tool remains stable on the rest, helping to reduce catches and allowing for smooth, controlled detailing as you refine your work to a finished result.\u003c\/p\u003e\u003cp\u003eEasy Wood Tools’ long‑lasting carbide cutters hold an edge many times longer than HSS and are suitable for dry or green wood, as well as acrylics. With no sharpening needed, maintenance is simple — when the edge dulls, just loosen the fixing screw and rotate or replace the cutter.\u003c\/p\u003e\u003cp\u003eThe shaft is engraved with the corresponding carbide cutter reference number for easy identification.\u003c\/p\u003e\u003cp\u003eAll Easy Wood Tools are 100% made in the USA.\u003c\/p\u003e\u003cp\u003eSpecifications\u003c\/p\u003e\u003cp\u003eTool type: Mini carbide detailing tool\u003c\/p\u003e\u003cp\u003eCutter type: Diamond‑shaped carbide cutter\u003c\/p\u003e\u003cp\u003eRange: Mini (compact tools with added stability over Micro)\u003c\/p\u003e\u003cp\u003eBar profile: Flat section for stability on the tool rest\u003c\/p\u003e\u003cp\u003eHandle: Hardwood with copper ferrule\u003c\/p\u003e\u003cp\u003eNegative rake carbide cutters are available separately and are particularly effective on acrylics, polyester, and resin, helping to achieve a smoother finish and greater control on more delicate or brittle materials.\u003c\/p\u003e","brand":"Easy Wood Tools","offers":[{"title":"Default Title","offer_id":54136159600987,"sku":"109318","price":110.0,"currency_code":"EUR","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0962\/0652\/0667\/files\/109318_xl.jpg?v=1790004763","url":"https:\/\/www.axminstertools.com\/products\/easy-wood-tools-mini-easy-detailer","provider":"Axminster Tools","version":"1.0","type":"link"}
