{"product_id":"easy-wood-tools-mini-easy-hollower-1","title":"Easy Wood Tools Mini EASY HOLLOWER™ #1","description":"\u003cp\u003eThe Easy Wood Tools Mini Easy Hollower™ #1 is a carbide woodturning tool designed for removing the bulk of material from the interior of small hollow forms and bowls.\u003c\/p\u003e\u003cp\u003eAs the first stage in the Mini hollowing system, it is ideal for opening up the centre of small vessels, boxes, and light hollow forms, where control and visibility are key.\u003c\/p\u003e\u003cp\u003eFitted with a replaceable carbide cutter and a rigid hollowing shaft, the Mini Easy Hollower™ #1 offers excellent stability when working inside smaller forms.\u003c\/p\u003e\u003cp\u003eIts compact yet more substantial size than Micro tools provides a reassuring balance between control and capability, while the flat tool support ensures it sits securely on the rest.\u003c\/p\u003e\u003cp\u003eWith no sharpening required, it simplifies hollowing for both beginners and more experienced turners.\u003c\/p\u003e\u003cp\u003eThe Mini Easy Hollower™ #1 is designed for efficient, controlled bulk removal inside smaller workpieces, allowing you to quickly establish the internal cavity.\u003c\/p\u003e\u003cp\u003eIts shaft design provides the stiffness needed to reduce chatter while working inside the form, and when used parallel to the floor at centre height, the tool remains stable on the rest. This helps to minimise catches and maintain predictable cutting action as you begin the hollowing process before moving on to #2 and #3 for refinement.\u003c\/p\u003e\u003cp\u003eEasy Wood Tools’ long‑lasting carbide cutters hold an edge many times longer than HSS and are suitable for dry or green wood, as well as acrylics. With no sharpening needed, maintenance is simple — when the edge dulls, just loosen the fixing screw and rotate or replace the cutter.\u003c\/p\u003e\u003cp\u003eThe shaft is engraved with the corresponding carbide cutter reference number for easy identification.\u003c\/p\u003e\u003cp\u003eAll Easy Wood Tools are 100% made in the USA.\u003c\/p\u003e\u003cp\u003eSpecifications\u003c\/p\u003e\u003cp\u003eTool type: Mini carbide hollowing tool (#1 – bulk removal)\u003c\/p\u003e\u003cp\u003eCutter type: Carbide hollowing cutter\u003c\/p\u003e\u003cp\u003eRange: Mini (compact tools for small hollow forms)\u003c\/p\u003e\u003cp\u003eShaft design: Hollowing shaft for internal access and stability\u003c\/p\u003e\u003cp\u003eHandle: Hardwood with copper ferrule\u003c\/p\u003e\u003cp\u003eNegative rake carbide cutters are available separately and are particularly effective on acrylics, polyester, and resin, helping to achieve smoother cuts and greater control when hollowing delicate or dense materials.\u003c\/p\u003e","brand":"Easy Wood Tools","offers":[{"title":"Default Title","offer_id":54118467961179,"sku":"109274","price":115.0,"currency_code":"EUR","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0962\/0652\/0667\/files\/109274_xl.jpg?v=1789781362","url":"https:\/\/www.axminstertools.com\/products\/easy-wood-tools-mini-easy-hollower-1","provider":"Axminster Tools","version":"1.0","type":"link"}
