{"product_id":"easy-wood-tools-mini-easy-hollower-2","title":"Easy Wood Tools Mini EASY HOLLOWER™ #2","description":"\u003cp\u003eThe Easy Wood Tools Mini Easy Hollower™ #2 is a carbide woodturning tool designed for refining the internal shape of small hollow forms after the bulk material has been removed.\u003c\/p\u003e\u003cp\u003eAs the second stage in the Mini hollowing system, it is ideal for shaping the interior of small vessels, boxes, and compact bowls, preparing the form for final refinement.\u003c\/p\u003e\u003cp\u003eFitted with a replaceable carbide cutter and a rigid hollowing shaft, the Mini Easy Hollower™ #2 offers excellent control when working inside partially hollowed forms.\u003c\/p\u003e\u003cp\u003eIts compact size with added substance over Micro tools provides a confident feel in the hand, while the stable tool profile sits securely on the rest.\u003c\/p\u003e\u003cp\u003eWith no sharpening required, it allows turners to focus on shaping rather than tool maintenance.\u003c\/p\u003e\u003cp\u003eThe Mini Easy Hollower™ #2 is designed for controlled interior shaping, following the profile created by Hollower #1 and refining the developing form.\u003c\/p\u003e\u003cp\u003eIts shaft provides the stiffness needed to minimise chatter as you work deeper into the piece, and when used parallel to the floor at centre height, it maintains steady contact with the tool rest. This helps deliver smooth, predictable cuts even in areas where visibility becomes more limited, setting up the final refinement stage with Hollower #3.\u003c\/p\u003e\u003cp\u003eEasy Wood Tools’ long‑lasting carbide cutters hold an edge many times longer than HSS and are suitable for dry or green wood, as well as acrylics. With no sharpening needed, maintenance is simple — when the edge dulls, just loosen the fixing screw and rotate or replace the cutter.\u003c\/p\u003e\u003cp\u003eThe shaft is engraved with the corresponding carbide cutter reference number for easy identification.\u003c\/p\u003e\u003cp\u003eAll Easy Wood Tools are 100% made in the USA.\u003c\/p\u003e\u003cp\u003eSpecifications\u003c\/p\u003e\u003cp\u003eTool type: Mini carbide hollowing tool (#2 – shaping stage)\u003c\/p\u003e\u003cp\u003eCutter type: Carbide hollowing cutter\u003c\/p\u003e\u003cp\u003eRange: Mini (compact tools for small hollow forms)\u003c\/p\u003e\u003cp\u003eShaft design: Hollowing shaft for controlled internal shaping\u003c\/p\u003e\u003cp\u003eHandle: Hardwood with copper ferrule\u003c\/p\u003e\u003cp\u003eNegative rake carbide cutters are available separately and are particularly effective on acrylics, polyester, and resin, helping to improve control and produce a smoother finish when working inside tighter cavities.\u003c\/p\u003e","brand":"Easy Wood Tools","offers":[{"title":"Default Title","offer_id":54118468026715,"sku":"109206","price":120.0,"currency_code":"EUR","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0962\/0652\/0667\/files\/109206_xl.jpg?v=1789781370","url":"https:\/\/www.axminstertools.com\/products\/easy-wood-tools-mini-easy-hollower-2","provider":"Axminster Tools","version":"1.0","type":"link"}
