{"product_id":"easy-wood-tools-mini-easy-hollowing-set-3-piece","title":"Easy Wood Tools Mini Easy Hollowing™ Set 3-Piece","description":"\u003cp\u003eThe Easy Wood Tools Mini Easy Hollowing™ Set 3‑Piece provides a complete solution for hollowing small vessels, boxes, and compact hollow forms, combining all three stages of the hollowing process in one set.\u003c\/p\u003e\u003cp\u003eIncluding Mini Easy Hollower™ #1, #2, and #3, it allows you to move from bulk material removal through shaping to final internal refinement, all with tools designed for control on smaller workpieces.\u003c\/p\u003e\u003cp\u003eEach tool in the set is fitted with a replaceable carbide cutter and designed to sit securely on the tool rest, making the hollowing process predictable and easy to control.\u003c\/p\u003e\u003cp\u003eThe Mini range offers more stability and cutting capability than Micro tools, while remaining compact enough for smaller projects.\u003c\/p\u003e\u003cp\u003eCombined with the no‑sharpening system, this set makes hollowing more accessible, helping turners focus on technique rather than tool maintenance.\u003c\/p\u003e\u003cp\u003eWorking as a progressive 1‑2‑3 system, the Mini hollowers guide you through the complete hollowing workflow. Hollower #1 quickly removes the bulk of interior material, Hollower #2 refines and shapes the developing form, and Hollower #3 provides controlled reach for final internal finishing.\u003c\/p\u003e\u003cp\u003eThe tool shafts are designed to reduce chatter and maintain stability inside the vessel, even as you work deeper into the form. Used parallel to the floor at centre height, each tool sits securely on the rest, helping to minimise catches and deliver smooth, controlled cuts throughout the process.\u003c\/p\u003e\u003cp\u003eEasy Wood Tools’ long‑lasting carbide cutters hold an edge many times longer than HSS and are suitable for dry or green wood, as well as acrylics. With no sharpening needed, maintenance is simple - when the edge dulls, just loosen the fixing screw and rotate or replace the cutter.\u003c\/p\u003e\u003cp\u003eThe shaft is engraved with the corresponding carbide cutter reference number for easy identification.\u003c\/p\u003e\u003cp\u003eAll Easy Wood Tools are 100% made in the USA.\u003c\/p\u003e\u003cp\u003eSpecifications\u003c\/p\u003e\u003cp\u003eSet includes: Mini Easy Hollower™ #1, #2, #3\u003c\/p\u003e\u003cp\u003eCutter type: Carbide hollowing cutters\u003c\/p\u003e\u003cp\u003eRange: Mini (compact tools suited to small hollow forms)\u003c\/p\u003e\u003cp\u003eSystem: Progressive hollowing set (bulk removal, shaping, finishing)\u003c\/p\u003e\u003cp\u003eHandles: Hardwood with copper ferrules\u003c\/p\u003e\u003cp\u003eNegative rake carbide cutters are available separately and are particularly effective on acrylics, polyester, and resin, helping to improve control and produce a smoother finish when hollowing delicate or dense materials.\u003c\/p\u003e","brand":"Easy Wood Tools","offers":[{"title":"Default Title","offer_id":54118476448091,"sku":"109276","price":310.0,"currency_code":"EUR","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0962\/0652\/0667\/files\/109276_xl.jpg?v=1789781671","url":"https:\/\/www.axminstertools.com\/products\/easy-wood-tools-mini-easy-hollowing-set-3-piece","provider":"Axminster Tools","version":"1.0","type":"link"}
