{"product_id":"easy-wood-tools-pro-easy-detailer","title":"Easy Wood Tools Pro EASY DETAILER™","description":"\u003cp\u003eThe Easy Wood Tools Pro Easy Detailer™ is a carbide woodturning tool designed for creating fine details, beads, crisp transitions, and tight‑radius decorative features on large bowls, oversized platters, spindles, table legs, sculptural pieces, and other substantial turning projects.\u003c\/p\u003e\u003cp\u003eAs part of the largest and heaviest‑duty range in the Easy Wood line up, the Pro Easy Detailer™ delivers exceptional reach and stability, making precision detailing safer, smoother, and more controlled - even on big, demanding workpieces.\u003c\/p\u003e\u003cp\u003eFeaturing a diamond‑shaped replaceable carbide cutter and a robust 12.7mm square section bar, the Pro Easy Detailer™ sits flat and steady on the tool rest, providing predictable control with no sharpening required.\u003c\/p\u003e\u003cp\u003eThe substantial 508mm American Hickory handle offers maximum leverage and vibration damping, giving turners confident handling during delicate detail work on large forms where accuracy and tool stability are critical.\u003c\/p\u003e\u003cp\u003eEngineered for deep reach and intricate precision, the Pro Easy Detailer™ produces clean, sharp detailing cuts on larger or harder‑to‑manage pieces.\u003c\/p\u003e\u003cp\u003eWith the tool held parallel to the floor at centre height, the square bar maintains excellent stability on the rest, helping to minimise catches and snatches, even when working inside wide bowls or along lengthy spindles.\u003c\/p\u003e\u003cp\u003eIts weight and geometry make it exceptionally effective for adding fine accents, shaping beads, sharpening transitions, and achieving crisp decorative features on substantial turning projects.\u003c\/p\u003e\u003cp\u003eWith no sharpening necessary, simply loosen the fixing screw and rotate the cutter to expose a fresh, sharp edge when dull.\u003c\/p\u003e\u003cp\u003eEasy Wood Tools’ premium solid carbide outlasts HSS many times over and performs reliably on dry or green wood, acrylics, and resin.\u003c\/p\u003e\u003cp\u003eAll Easy Wood Tools are 100% made in the USA.\u003c\/p\u003e\u003cp\u003eWhat you get\u003c\/p\u003e\u003cp\u003eDiamond‑shaped carbide cutter fitted as standard\u003c\/p\u003e\u003cp\u003eHex key for quick cutter rotation or replacement\u003c\/p\u003e\u003cp\u003e508mm American Hickory handle with copper ferrule for strength\u003c\/p\u003e\u003cp\u003e12.7mm square section bar for maximum stability on the tool rest\u003c\/p\u003e\u003cp\u003eColour‑coded handle for quick range identification\u003c\/p\u003e\u003cp\u003eShaft engraved with the carbide cutter reference number\u003c\/p\u003e\u003cp\u003eSpecifications\u003c\/p\u003e\u003cp\u003eOverall length: 724mm\u003c\/p\u003e\u003cp\u003eHandle length: 508mm\u003c\/p\u003e\u003cp\u003eBar profile: 12.7mm square\u003c\/p\u003e\u003cp\u003eOptional upgrade\u003c\/p\u003e\u003cp\u003eNegative rake carbide cutters are available separately and work especially well on acrylics, polyester, and resin, delivering a smoother, finer finish on timber while enhancing control on tricky grain or brittle materials.\u003c\/p\u003e","brand":"Easy Wood Tools","offers":[{"title":"Default Title","offer_id":54136160190811,"sku":"109256","price":165.0,"currency_code":"EUR","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0962\/0652\/0667\/files\/109256_xl.jpg?v=1790004781","url":"https:\/\/www.axminstertools.com\/products\/easy-wood-tools-pro-easy-detailer","provider":"Axminster Tools","version":"1.0","type":"link"}
