{"product_id":"easy-wood-tools-pro-easy-finisher","title":"Easy Wood Tools Pro EASY FINISHER™","description":"\u003cp\u003eThe Easy Wood Tools Pro Easy Finisher™ is a carbide woodturning tool designed for making coves, smoothing hollows, refining sweeping curves, and producing clean final shapes on large bowls, oversized platters, long spindles, table legs, and other substantial turning projects.\u003c\/p\u003e\u003cp\u003eAs part of the largest, most substantial range in the Easy Wood line up, the Pro Easy Finisher™ provides maximum leverage and reach, making it ideal for finishing work on big, heavy workpieces.\u003c\/p\u003e\u003cp\u003eFeaturing a replaceable round carbide cutter and a robust 12.7mm square section bar, the Pro Easy Finisher™ sits flat and stable on your tool rest, offering smooth, predictable control with no sharpening required.\u003c\/p\u003e\u003cp\u003eIts extra‑long 508mm American Hickory handle is engineered for power, leverage, and reduced fatigue, allowing turners to refine wide curves and deep hollows on large forms with confidence and comfort—even during long turning sessions.\u003c\/p\u003e\u003cp\u003eThe Pro Easy Finisher™ is engineered to deliver smooth, flowing finishing cuts across large surfaces. It excels at refining hollow forms, blending contours, shaping the interiors of wide bowls, and smoothing exterior curves before sanding.\u003c\/p\u003e\u003cp\u003eHeld parallel to the floor at centre height, the square bar ensures exceptional stability on the tool rest, helping to minimise catches and snatches even when working on heavy, dense, or oversized blanks.\u003c\/p\u003e\u003cp\u003eIts mass and reach make it ideal for turning situations where control and balance are essential for producing clean, consistent finishing cuts.\u003c\/p\u003e\u003cp\u003eWith no sharpening required, simply rotate the cutter to a fresh edge when dull.\u003c\/p\u003e\u003cp\u003eEasy Wood Tools’ premium solid carbide lasts many times longer than HSS and performs reliably on dry or green wood, acrylics, and resin.\u003c\/p\u003e\u003cp\u003eAll Easy Wood Tools are 100% made in the USA.\u003c\/p\u003e\u003cp\u003eWhat you get\u003c\/p\u003e\u003cp\u003eRound carbide cutter fitted as standard\u003c\/p\u003e\u003cp\u003eHex key for easy cutter rotation or replacement\u003c\/p\u003e\u003cp\u003e508mm American Hickory handle with copper ferrule for strength\u003c\/p\u003e\u003cp\u003e12.7mm square section bar for maximum stability\u003c\/p\u003e\u003cp\u003eColour‑coded handle for fast range identification\u003c\/p\u003e\u003cp\u003eShaft engraved with the carbide cutter reference number\u003c\/p\u003e\u003cp\u003eSpecifications\u003c\/p\u003e\u003cp\u003eOverall length: 724mm\u003c\/p\u003e\u003cp\u003eHandle length: 508mm\u003c\/p\u003e\u003cp\u003eBar profile: 12.7mm square\u003c\/p\u003e\u003cp\u003eOptional upgrade\u003c\/p\u003e\u003cp\u003eNegative rake carbide cutters are available separately and perform exceptionally well on acrylics, polyester, and resin, producing a smoother, cleaner finish on timber—especially valuable during fine shaping and final cuts.\u003c\/p\u003e","brand":"Easy Wood Tools","offers":[{"title":"Default Title","offer_id":54118469042523,"sku":"109255","price":165.0,"currency_code":"EUR","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0962\/0652\/0667\/files\/109255_xl.jpg?v=1789781447","url":"https:\/\/www.axminstertools.com\/products\/easy-wood-tools-pro-easy-finisher","provider":"Axminster Tools","version":"1.0","type":"link"}
