{"product_id":"easy-wood-tools-pro-easy-hollower-1","title":"Easy Wood Tools Pro EASY HOLLOWER™ #1","description":"\u003cp\u003eThe Easy Wood Tools Pro Easy Hollower™ #1 is the first tool in the Pro hollowing 1‑2‑3 system, designed for removing the bulk of interior waste from large hollow forms and from the centre of medium and large bowls.\u003c\/p\u003e\u003cp\u003eAs part of the Pro range, it offers the greatest leverage, reach, and stability, making it ideal for safely opening up deep forms and tackling substantial hollowing work with confidence.\u003c\/p\u003e\u003cp\u003eThe Pro Easy Hollower™ #1 features a solid carbide cutting tip and a 12.7mm × 19mm rectangular shaft that provides superior stiffness and tool‑rest stability during heavy waste removal.\u003c\/p\u003e\u003cp\u003eThe extra‑long 508mm American Maple handle delivers exceptional control and reduces fatigue when rough hollowing large pieces.\u003c\/p\u003e\u003cp\u003eLike all Easy Wood Tools, it requires no sharpening—when a cutting edge dulls, simply rotate the cutter to a fresh one.\u003c\/p\u003e\u003cp\u003eHollower #1 is engineered for efficient, controlled bulk removal inside hollow forms.\u003c\/p\u003e\u003cp\u003eThe rectangular shaft improves reach and rigidity, minimising tool chatter while working deep in the vessel. When held parallel to the floor at centre height, the tool stays flat on the rest and helps reduce catches, even when cutting into unseen interior walls.\u003c\/p\u003e\u003cp\u003eThis tool begins shaping the internal cavity before refinement with Hollower #2 and final shaping with Hollower #3.\u003c\/p\u003e\u003cp\u003eAll Pro hollowers feature replaceable, long‑lasting carbide cutters that outperform HSS and require no sharpening.\u003c\/p\u003e\u003cp\u003eSuitable for dry or green wood, acrylics, and resin, and 100% made in the USA.\u003c\/p\u003e\u003cp\u003eWhat you get\u003c\/p\u003e\u003cp\u003eSolid carbide cutter fitted as standard\u003c\/p\u003e\u003cp\u003e508mm American Maple handle with copper ferrule\u003c\/p\u003e\u003cp\u003e12.7mm × 19mm rectangular hollowing shaft\u003c\/p\u003e\u003cp\u003eShaft engraved with cutter reference number\u003c\/p\u003e\u003cp\u003eColour‑coded handle for quick tool identification\u003c\/p\u003e\u003cp\u003eSpecifications\u003c\/p\u003e\u003cp\u003eOverall length: 812mm\u003c\/p\u003e\u003cp\u003eHandle length: 508mm\u003c\/p\u003e\u003cp\u003eReach: ~200mm\u003c\/p\u003e\u003cp\u003eShaft profile: 12.7mm × 19mm rectangular\u003c\/p\u003e\u003cp\u003eOptional upgrade\u003c\/p\u003e\u003cp\u003eNegative rake cutters are available separately for smoother results on acrylics, polyester, resin, and tricky grain.\u003c\/p\u003e","brand":"Easy Wood Tools","offers":[{"title":"Default Title","offer_id":54118469239131,"sku":"109265","price":195.0,"currency_code":"EUR","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0962\/0652\/0667\/files\/109265_xl.jpg?v=1789781456","url":"https:\/\/www.axminstertools.com\/products\/easy-wood-tools-pro-easy-hollower-1","provider":"Axminster Tools","version":"1.0","type":"link"}
