{"product_id":"easy-wood-tools-pro-easy-hollower-2","title":"Easy Wood Tools Pro EASY HOLLOWER™ #2","description":"\u003cp\u003eThe Easy Wood Tools Pro Easy Hollower™ #2 is the mid‑stage shaping tool in the Pro 1‑2‑3 hollowing system, designed to refine the internal shape of large hollow forms after the bulk waste has been removed with Hollower #1.\u003c\/p\u003e\u003cp\u003eAs part of the largest, most robust range in the Easy Wood lineup, the Pro Easy Hollower™ #2 delivers the reach, leverage, and rigidity required to shape deep interior walls on big, demanding workpieces with accuracy and confidence.\u003c\/p\u003e\u003cp\u003eFeaturing a solid carbide cutter and a 12.7mm × 19mm rectangular shaft, the Pro Easy Hollower™ #2 offers outstanding stability on the tool rest and significantly reduces chatter during deeper shaping cuts.\u003c\/p\u003e\u003cp\u003eIts extra‑long 508mm American Maple handle provides exceptional leverage and balance, helping turners maintain smooth, controlled cutting action even when working inside partially enclosed or deep forms.\u003c\/p\u003e\u003cp\u003eLike all Easy Wood Tools, there is no sharpening required—simply rotate the cutter to a fresh edge.\u003c\/p\u003e\u003cp\u003eEngineered for controlled internal shaping, the Pro Easy Hollower™ #2 follows the developing contour of the vessel, smoothing transitions and refining the interior profile left by Hollower #1.\u003c\/p\u003e\u003cp\u003eThe rigid rectangular shaft gives improved reach and stiffness, keeping cuts predictable at extended distances from the tool rest.\u003c\/p\u003e\u003cp\u003eWhen used parallel to the floor at centre height, the tool stays flat and stable, helping to minimise catches and snatches in areas where visibility is limited.\u003c\/p\u003e\u003cp\u003eIt prepares the internal surface for the deep‑reach, fine‑refinement work of Hollower #3.\u003c\/p\u003e\u003cp\u003eAll Pro Easy Hollowers feature replaceable, long‑lasting carbide cutters that outperform HSS many times over.\u003c\/p\u003e\u003cp\u003eThey are suitable for turning dry or green wood, acrylics, and resin, and are 100% made in the USA.\u003c\/p\u003e\u003cp\u003eWhat you get\u003c\/p\u003e\u003cp\u003eSolid carbide cutter fitted as standard\u003c\/p\u003e\u003cp\u003e508mm American Maple handle with copper ferrule\u003c\/p\u003e\u003cp\u003e12.7mm × 19mm rectangular shaft for maximum rigidity\u003c\/p\u003e\u003cp\u003eColour‑coded handle for quick identification\u003c\/p\u003e\u003cp\u003eShaft engraved with cutter reference number\u003c\/p\u003e\u003cp\u003eSpecifications\u003c\/p\u003e\u003cp\u003eOverall length: 812mm\u003c\/p\u003e\u003cp\u003eHandle length: 508mm\u003c\/p\u003e\u003cp\u003eShaft profile: 12.7mm × 19mm rectangular\u003c\/p\u003e\u003cp\u003eReach: Approximately 200mm\u003c\/p\u003e\u003cp\u003eOptional upgrade\u003c\/p\u003e\u003cp\u003eNegative rake carbide cutters are available separately, providing a smoother finish on acrylics, polyester, resin, and challenging grain patterns.\u003c\/p\u003e","brand":"Easy Wood Tools","offers":[{"title":"Default Title","offer_id":54118469337435,"sku":"109266","price":230.0,"currency_code":"EUR","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0962\/0652\/0667\/files\/109266_xl.jpg?v=1789781463","url":"https:\/\/www.axminstertools.com\/products\/easy-wood-tools-pro-easy-hollower-2","provider":"Axminster Tools","version":"1.0","type":"link"}
