{"product_id":"easy-wood-tools-pro-easy-hollower-3","title":"Easy Wood Tools Pro EASY HOLLOWER™ #3","description":"\u003cp\u003eThe Easy Wood Tools Pro Easy Hollower™ #3 is the final‑stage, deep‑reach tool in the Pro hollowing system, designed to access deep internal cavities and perform the last stage of hollow form refinement on large vessels, vases, sculptural forms, and substantial bowls.\u003c\/p\u003e\u003cp\u003eAs part of the largest and most robust range in the Easy Wood lineup, the Pro Hollower™ #3 provides unmatched reach, leverage, and stability, making it essential for turners working on deep, enclosed, or oversized hollow forms.\u003c\/p\u003e\u003cp\u003eFeaturing a solid carbide cutter and a rigid 12.7mm × 19mm rectangular shaft, the Pro Easy Hollower™ #3 provides exceptional stiffness and reduces chatter at maximum extension—critical when shaping deep, unseen interior walls.\u003c\/p\u003e\u003cp\u003eThe 508mm straight‑grained American Hickory handle offers superior leverage, balance, and comfort during long sessions, supporting smooth, controlled cutting even in the deepest parts of a vessel.\u003c\/p\u003e\u003cp\u003eAnd, as with all Easy Wood Tools, no sharpening is required—simply rotate the cutter for a fresh edge.\u003c\/p\u003e\u003cp\u003eEngineered for deep interior shaping and final surface refinement, the Pro Easy Hollower™ #3 excels when working far from the tool rest or inside narrow openings. Its rectangular shaft provides the rigidity needed for long‑reach cutting, helping to maintain wall thickness, refine contours, and achieve smooth interior surfaces before sanding.\u003c\/p\u003e\u003cp\u003eUsed parallel to the floor at centre height, the tool remains stable on the rest and helps minimise catches and snatches, even when cutting inside invisible cavities.\u003c\/p\u003e\u003cp\u003eHollower #3 brings the form to its final interior finish after the waste removal of Hollower #1 and the mid‑stage shaping of Hollower #2.\u003c\/p\u003e\u003cp\u003eAll Pro hollowers use long‑lasting carbide cutters that require no sharpening and outperform HSS by a significant margin.\u003c\/p\u003e\u003cp\u003eThey can be used on dry or green wood, acrylics, and resin, and are 100% made in the USA.\u003c\/p\u003e\u003cp\u003eWhat you get\u003c\/p\u003e\u003cp\u003eSolid carbide cutter fitted as standard\u003c\/p\u003e\u003cp\u003e508mm American Hickory handle with copper ferrule\u003c\/p\u003e\u003cp\u003e12.7mm × 19mm rectangular shaft for maximum rigidity\u003c\/p\u003e\u003cp\u003eColour‑coded handle for fast identification\u003c\/p\u003e\u003cp\u003eShaft engraved with the cutter reference number\u003c\/p\u003e\u003cp\u003eSpecifications\u003c\/p\u003e\u003cp\u003eOverall length: 812mm\u003c\/p\u003e\u003cp\u003eHandle length: 508mm\u003c\/p\u003e\u003cp\u003eShaft profile: 12.7mm × 19mm rectangular\u003c\/p\u003e\u003cp\u003eDeep‑reach capability: approx. 200mm\u003c\/p\u003e\u003cp\u003eOptional upgrade\u003c\/p\u003e\u003cp\u003eNegative rake carbide cutters are available separately and provide enhanced control and a smoother finish on acrylics, resin, polyester materials, and difficult grain patterns—ideal for final interior refinement.\u003c\/p\u003e","brand":"Easy Wood Tools","offers":[{"title":"Default Title","offer_id":54118469402971,"sku":"109267","price":230.0,"currency_code":"EUR","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0962\/0652\/0667\/files\/109267_xl.jpg?v=1789781471","url":"https:\/\/www.axminstertools.com\/products\/easy-wood-tools-pro-easy-hollower-3","provider":"Axminster Tools","version":"1.0","type":"link"}
