{"product_id":"easy-wood-tools-pro-easy-rougher","title":"Easy Wood Tools Pro EASY ROUGHER™","description":"\u003cp\u003eThe Easy Wood Tools Pro Easy Rougher™ is a carbide woodturning tool designed for rapid, controlled material removal when turning large bowls, oversized platters, long spindles, table legs, and other substantial projects.\u003c\/p\u003e\u003cp\u003eAs the largest and most robust tools in the Easy Wood range, the Pro series provides maximum leverage, reach, and stability, making it ideal for heavy‑duty turning and extended sessions at the lathe.\u003c\/p\u003e\u003cp\u003eEquipped with a square replaceable carbide cutter featuring a 100mm corner radius, the Pro Easy Rougher™ delivers smooth, predictable cutting with no sharpening required.\u003c\/p\u003e\u003cp\u003eThe substantial 12.7mm square section bar keeps the tool flat and steady on the rest, while the extra‑long 508mm American Hickory handle provides exceptional control, power, and reduced fatigue when working on the largest workpieces.\u003c\/p\u003e\u003cp\u003eThe Pro Easy Rougher™ is engineered for heavy stock removal, making it easy to shape large, dense, or deep blanks with confidence.\u003c\/p\u003e\u003cp\u003eWhen used parallel to the floor at centre height, the flat bar design ensures the tool remains stable, helping to minimise catches and snatches even during demanding cuts.\u003c\/p\u003e\u003cp\u003eIts weight, reach, and mass make it exceptionally efficient for rough shaping of big forms before switching to Pro finishing or detailing tools.\u003c\/p\u003e\u003cp\u003eWith no sharpening needed, simply rotate the cutter to a fresh edge when dull.\u003c\/p\u003e\u003cp\u003eEasy Wood Tools’ premium solid carbide outlasts HSS many times over and works effectively on dry or green wood, acrylics, and resin.\u003c\/p\u003e\u003cp\u003eAll Easy Wood Tools are 100% made in the USA.\u003c\/p\u003e\u003cp\u003eWhat you get\u003c\/p\u003e\u003cp\u003eSquare carbide cutter with slight 100mm radius\u003c\/p\u003e\u003cp\u003eHex key for easy cutter rotation or replacement\u003c\/p\u003e\u003cp\u003e508mm American Hickory handle with copper ferrule for strength\u003c\/p\u003e\u003cp\u003e12.7mm square section bar for maximum tool‑rest stability\u003c\/p\u003e\u003cp\u003eColour‑coded handle for quick recognition across the Pro range\u003c\/p\u003e\u003cp\u003eShaft engraved with the carbide cutter reference number\u003c\/p\u003e\u003cp\u003eSpecifications\u003c\/p\u003e\u003cp\u003eOverall length: 724mm\u003c\/p\u003e\u003cp\u003eHandle length: 508mm\u003c\/p\u003e\u003cp\u003eBar profile: 12.7mm square\u003c\/p\u003e\u003cp\u003eOptional upgrade\u003c\/p\u003e\u003cp\u003eNegative rake carbide cutters are available separately and excel when turning acrylics, polyester, and resin, also producing a smoother, cleaner finish on timber.\u003c\/p\u003e","brand":"Easy Wood Tools","offers":[{"title":"Default Title","offer_id":54136160387419,"sku":"109308","price":165.0,"currency_code":"EUR","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0962\/0652\/0667\/files\/109308_xl.jpg?v=1790004792","url":"https:\/\/www.axminstertools.com\/products\/easy-wood-tools-pro-easy-rougher","provider":"Axminster Tools","version":"1.0","type":"link"}
