The Easy Chuck is a 4-inch, 4-jaw chuck that features the patented Snap-Lock Technology, which allows for quick jaw changes that can be completed in approximately 30 seconds, without the need for screws. The Zoom Ring enables fast, one-handed adjustments of the jaws, making it easier to secure your workpiece. The jaws have rounded corners to enhance safety during use.
Use the supplied ball and hex key, press down on the keeper latch, slide each jaw off and slide your Easy Jaws into place. Listen for a snap, and the jaw will be locked into position and ready to use within 30 seconds.
Constructed with hardened and plated components, the Easy Chuck is durable, precise and machined to high tolerances.
This chuck is perfect for beginners and professionals alike.
Available in four body sizes to fit different lathe spindles: 1 x 8 TPI, 1.1/4 x 8 TPI, M30 x 3.5mm, M33 x 3.5mm.
Supplied with 1-3/8 Dovetail Easy Jaws, Easy Chucking Screw with a 3/8 & 1/2 double-ended design, Chuck Key - 5/16 Hex T-Handle, Jaw Key - 1/8 Ball End Hex Key, Spindle Washer, Spare Hub Set Screws, Spare Master Jaw Springs and a manual.
Thread Size 1 x 8 tpi
