The Einhell GC-DP 7035 LL 2-in-1 Combi Pump is a versatile solution for both clear and waste water removal—perfect for a wide range of domestic and garden tasks. With flat suction down to just 1mm residual water level, it ensures efficient water clearance. Switching between suction modes is easy with a simple twist of the rotary control.
Its infinitely adjustable float switch allows flexible operation, while a high-quality ceramic/rubber seal ensures long-lasting durability. The impact-resistant plastic housing and ergonomic carry handle make it tough and easy to transport. For added convenience, the pump includes integrated cable storage.
The unit comes with a 90° angled G11/2 connection and a universal adapter for 25/32 mm hoses and 33.3 mm (G1) fittings.
Specifications:
Input Power: 700W
Max. Delivery Capacity: 16,000 L/hr
Max. Delivery Height: 8m
Immersion Depth: 7m
Max. Particle Size: 35mm
Hose Connection: 47.8mm (G1½ IG)
Max. Water Temperature: 35°C
Power Cord Length: 10m
Web Attribute Set Hose Pipe Accessories
EAN Barcode 4006825662085
