The Einhell GE-CG 18/100 Li-Solo Power X-Change Grass & Bush Shear is a convenient alternative to hand-operated pruning saws or garden shears. It is also lighter, quieter and more versatile than the petrol-powered or electronic versions and is therefore an ideal helper when it comes to pruning, shaping and thinning out shrubs and trees.
Comes with a grass cutting blade, perfectly suited for cutting lawn edges (100mm), and a laser-cut, diamond-ground shrub blade that is ideal for trimming hedges and bushes. These tools are easy to change over, without the need for any other tools. The soft grip provides a perfect grip and ergonomics for every movement during use.
Covered gearing housing provides protection during use and when cleaning against contact with parts which are lubricated with gear oil.
Supplied as body only (no battery or charger).
Specification:
Cutting Width: Grass Shear 100mm, Shrub Knife: 200mm
Cutting Thickness: Shrub Cutting Knife: 8mm
Weight: 1.06kg
Battery Voltage 18 V
Battery Type Li-ion
Web Attribute Set Cordless Hedgecutters
EAN Barcode 4006825652710
