{"product_id":"einhell-ge-cg-18-100li-grass-bush-shear-18v-body-only","title":"Einhell GE-CG 18\/100Li Grass \u0026 Bush Shear 18V (Body Only)","description":"\u003cp\u003eThe Einhell GE-CG 18\/100 Li-Solo Power X-Change Grass \u0026amp; Bush Shear is a convenient alternative to hand-operated pruning saws or garden shears. It is also lighter, quieter and more versatile than the petrol-powered or electronic versions and is therefore an ideal helper when it comes to pruning, shaping and thinning out shrubs and trees.\u003c\/p\u003e\u003cp\u003eComes with a grass cutting blade, perfectly suited for cutting lawn edges (100mm), and a laser-cut, diamond-ground shrub blade that is ideal for trimming hedges and bushes. These tools are easy to change over, without the need for any other tools. The soft grip provides a perfect grip and ergonomics for every movement during use.\u003c\/p\u003e\u003cp\u003eCovered gearing housing provides protection during use and when cleaning against contact with parts which are lubricated with gear oil.\u003c\/p\u003e\u003cp\u003eSupplied as body only (no battery or charger).\u003c\/p\u003e\u003cp\u003eSpecification:\u003c\/p\u003e\u003cp\u003eCutting Width: Grass Shear 100mm, Shrub Knife: 200mm\u003c\/p\u003e\u003cp\u003eCutting Thickness: Shrub Cutting Knife: 8mm\u003c\/p\u003e\u003cp\u003eWeight: 1.06kg\u003c\/p\u003e","brand":"Einhell","offers":[{"title":"Default Title","offer_id":54118776799579,"sku":"113513","price":52.98,"currency_code":"GBP","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0962\/0652\/0667\/files\/113513_xl.jpg?v=1789791425","url":"https:\/\/www.axminstertools.com\/products\/einhell-ge-cg-18-100li-grass-bush-shear-18v-body-only","provider":"Axminster Tools","version":"1.0","type":"link"}
