The Einhell GE-CH 1855/1 Li Power X-Change Hedge Trimmer with metal gearing for long service life. Its blades are made from laser-cut and diamond-ground steel for clean-cutting results. Fitted with a swivel handle and an additional adjustable handle for increased comfort and reduced fatigue. A two-hand switch increases user safety.
The cutting collector can be added to the top of the blade to sweep away clipping making it ideal for removing cuttings from the top of a hedge.
Supplied with; cuttings collector, a sturdy cutter guard for storage and transportation, 1 x 2.5Ah Li-ion Battery and 1 x Charger.
Specification:
Strokes at No Load: 2,200/min.
Cutting Length: 550mm
Blade Length: 620mm
Spacing Between Teeth: 18mm
Weight: 2.6kg
Battery Capacity 2.5 Ah
Battery Voltage 18 V
Sound Power Level LwA [Uncertainty K] 91 dB(A)
Batteries Included 1
Battery Type Li-ion
Sound Pressure Level LpA [Uncertainty K] 81 dB(A)
Web Attribute Set Cordless Hedgecutters
EAN Barcode 4006825661910
