Einhell Power X-Change Multi-Ah Battery features high-quality Li-ion cells with no memory effect, low self-discharge and high, constant power. This cell technology delivers 100% more power for maximum performance.
With Multi-Ah technology: 6.0Ah for maximum charge level or 4.0Ah to protect the battery for 3x longer total lifetime. The charge level is precisely indicated as a % on the digital display. PLUS-technology provides increased power for intensive operation.
The ABS process-controlled battery management system stands for maximum safety, optimum performance, operating time and lifetime. Covered with a rubber-coated housing which provides increased impact protection and protects against dust, corrosion and mechanical damage.
Compatible with all Power X-Change chargers, machines and for twin battery use in demanding 36V power applications.
Battery Capacity 6.0 Ah
Battery Voltage 18 V
Batteries Included 1
Battery Type Li-ion
Web Attribute Set Batteries
EAN Barcode 4006825644210
