{"product_id":"einhell-tc-bg-200-l-bench-grinder-400w-230v","title":"Einhell TC-BG 200 L Bench Grinder 400W 230V","description":"\u003cp\u003eThe Einhell TC‑BG 200 L Bench Grinder is a versatile grinding and sanding machine designed for a wide range of workshop tasks. Powered by a single motor driving two wheels, it’s a dependable and essential tool for any workshed.\u003c\/p\u003e\u003cp\u003eThis double‑wheel grinder is ideal for sharpening scissors, knives, blades, drill bits, cutters, and chisels. It’s also suitable for derusting, deburring, polishing, and shaping workpieces made from wood, plastic, or metal. Whether you're carrying out minor touch‑ups or heavier repairs, the TC‑BG 200 L delivers consistent, reliable performance.\u003c\/p\u003e\u003cp\u003eA robust, compact metal design ensures long service life, while large adjustable work supports provide flexibility for different applications. Its ball‑bearing mounted shaft operates smoothly with zero play for precise results. Safety features include tool‑free adjustable spark guards and side‑closed protective hoods. Four rubber feet reduce vibration and provide a stable working position.\u003c\/p\u003e\u003cp\u003eThe unit comes fitted with both coarse and fine wheels (K36\/K60).\u003c\/p\u003e\u003cp\u003eSpecifications:\u003c\/p\u003e\u003cp\u003e\u003cspecial id=\"14\"\u003e\u003c\/special\u003e Input Power: 400W\u003c\/p\u003e\u003cp\u003e\u003cspecial id=\"14\"\u003e\u003c\/special\u003e No‑Load Speed: 2,980\/min\u003c\/p\u003e\u003cp\u003e\u003cspecial id=\"14\"\u003e\u003c\/special\u003e Coarse Disc Size: Ø200mm (32mm inner)\u003c\/p\u003e\u003cp\u003e\u003cspecial id=\"14\"\u003e\u003c\/special\u003e Fine Disc Size: Ø200mm (32mm inner)\u003c\/p\u003e\u003cp\u003e\u003cspecial id=\"14\"\u003e\u003c\/special\u003e Weight: 11.66kg\u003c\/p\u003e","brand":"Einhell","offers":[{"title":"Default Title","offer_id":54118841647451,"sku":"114113","price":84.0,"currency_code":"EUR","in_stock":false}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0962\/0652\/0667\/files\/114113_xl.jpg?v=1789793132","url":"https:\/\/www.axminstertools.com\/products\/einhell-tc-bg-200-l-bench-grinder-400w-230v","provider":"Axminster Tools","version":"1.0","type":"link"}
