The Einhell TC‑BG 200 L Bench Grinder is a versatile grinding and sanding machine designed for a wide range of workshop tasks. Powered by a single motor driving two wheels, it’s a dependable and essential tool for any workshed.
This double‑wheel grinder is ideal for sharpening scissors, knives, blades, drill bits, cutters, and chisels. It’s also suitable for derusting, deburring, polishing, and shaping workpieces made from wood, plastic, or metal. Whether you're carrying out minor touch‑ups or heavier repairs, the TC‑BG 200 L delivers consistent, reliable performance.
A robust, compact metal design ensures long service life, while large adjustable work supports provide flexibility for different applications. Its ball‑bearing mounted shaft operates smoothly with zero play for precise results. Safety features include tool‑free adjustable spark guards and side‑closed protective hoods. Four rubber feet reduce vibration and provide a stable working position.
The unit comes fitted with both coarse and fine wheels (K36/K60).
Specifications:
Input Power: 400W
No‑Load Speed: 2,980/min
Coarse Disc Size: Ø200mm (32mm inner)
Fine Disc Size: Ø200mm (32mm inner)
Weight: 11.66kg
Web Attribute Set Bench Grinders
EAN Barcode 4006825649918
