The Einhell TC-JS 18/70 Li Cordless Jigsaw is a versatile 18V battery-powered saw for cutting curves, straight lines and angled edges in a range of materials. With variable speed control, a switchable pendulum action and a maximum cutting depth of 70mm in wood, it offers flexibility for DIY projects, home improvements and workshop tasks. The tool-free blade changing system makes swapping blades straightforward, while the integrated dust blower helps keep the cutting line visible. For added versatility, the saw can make bevel cuts up to 45° and features a protective baseplate cover to help prevent marks on delicate workpieces.
Supplied ready to get started, this Einhell cordless jigsaw kit includes a 2.5Ah 18V Power X-Change lithium-ion battery and charger, along with a wood-cutting jigsaw blade, dust extraction adapter, splinter guard and hex key for adjusting the cutting angle. The dust extraction connection helps manage sawdust when connected to a suitable vacuum, while the splinter guard helps produce cleaner cuts. Comfortable soft-grip handles and cordless convenience make it a practical addition to the home workshop or an existing Power X-Change tool collection.
Einhell is a German power tool and garden equipment manufacturer known for its broad range of accessible, practical tools for DIY users and home workshops. Its Power X-Change battery platform allows compatible 18V tools to share the same battery system, offering flexibility across a growing range of cordless equipment.
Supplied with 1 x 18V 2.5Ah Power X-Change lithium-ion battery, 1 x charger, 1 x jigsaw blade for wood, 1 x suction adaptor and 1 x hexagon key. Part of the Power X-Change series of tools and batteries, 3 Year Einhell Warranty, registration within 30 days required.
Battery Capacity 2.5 Ah
Battery Voltage 18 V
Dust Extraction 36 mm Outlet
Rating Home/Light Trade
Stroke Length 20 mm
Sound Power Level LwA [Uncertainty K] 90.5 dB(A)
Batteries Included 1
Battery Type Li-ion
Corded or Cordless Cordless
Sound Pressure Level LpA [Uncertainty K] 79.5 dB(A)
Web Attribute Set Cordless Jigsaws
EAN Barcode 4006825679519
