The Einhell TC-MG 135 E Grinding & Engraving Tool is a versatile rotary tool suitable for grinding, engraving, drilling, cutting, polishing and brushing applications. Its compact, ergonomic design features a soft-grip handle for comfortable use and electronic variable speed control, allowing performance to be matched to different materials and tasks.
A spindle lock enables fast and easy accessory changes, while the flexible shaft provides greater control for detailed work. For added convenience, the tool can be mounted to the supplied telescopic stand and hook, helping improve precision during use.
Supplied with an extensive 189-piece accessory kit, the TC-MG 135 E is ready for a wide range of workshop, hobby and DIY projects. The set includes grinding stones, sanding accessories, cutting discs, polishing tools, drill bits and more, all stored in a practical carry case.
Supplied with:
1 x Telescopic Table Clamp Stand
1 x Key for Tool Change & Transport
3 x Holders for Felt Polishing Discs
1 x Brush Insert
1 x Storage Case
The 189 Piece Accessory Set contains:
12 x Special Corundum Mounted Points
6 x Milling Pins
22 x Sanding Tools (14 x Small, 8 x Tall)
34 x Adaptors for Sanding Tools (20 x Small, 14 x Tall)
3 x Adaptors for Miniature Grinding & Cutting Discs
4 x Special Corundum Miniature Grinding Discs
40 x Miniature Cutting Discs
14 x Miniature Felt Polishing Discs (11 x Flat, 3 x Long)
46 x Round Sanding Papers
6 x HSS Drill Bits
Specifications:
Input Power: 135 Watt
No Load Speed: 10,000-35,000/min
Length: 340mm
Weight: 0.67kg
Web Attribute Set 230V Rotary Multitools
EAN Barcode 4006825585315
