{"product_id":"einhell-tc-mg135e-grinding-engraving-tool-kit-230v","title":"Einhell TC-MG135E Grinding \u0026 Engraving Tool Kit 230V","description":"\u003cp\u003eThe Einhell TC-MG 135 E Grinding \u0026amp; Engraving Tool is a versatile rotary tool suitable for grinding, engraving, drilling, cutting, polishing and brushing applications. Its compact, ergonomic design features a soft-grip handle for comfortable use and electronic variable speed control, allowing performance to be matched to different materials and tasks.\u003c\/p\u003e\u003cp\u003eA spindle lock enables fast and easy accessory changes, while the flexible shaft provides greater control for detailed work. For added convenience, the tool can be mounted to the supplied telescopic stand and hook, helping improve precision during use.\u003c\/p\u003e\u003cp\u003eSupplied with an extensive 189-piece accessory kit, the TC-MG 135 E is ready for a wide range of workshop, hobby and DIY projects. The set includes grinding stones, sanding accessories, cutting discs, polishing tools, drill bits and more, all stored in a practical carry case.\u003c\/p\u003e\u003cp\u003eSupplied with:\u003c\/p\u003e\u003cp\u003e1 x Telescopic Table Clamp Stand\u003c\/p\u003e\u003cp\u003e1 x Key for Tool Change \u0026amp; Transport\u003c\/p\u003e\u003cp\u003e3 x Holders for Felt Polishing Discs\u003c\/p\u003e\u003cp\u003e1 x Brush Insert\u003c\/p\u003e\u003cp\u003e1 x Storage Case\u003c\/p\u003e\u003cp\u003eThe 189 Piece Accessory Set contains:\u003c\/p\u003e\u003cp\u003e12 x Special Corundum Mounted Points\u003c\/p\u003e\u003cp\u003e6 x Milling Pins\u003c\/p\u003e\u003cp\u003e22 x Sanding Tools (14 x Small, 8 x Tall)\u003c\/p\u003e\u003cp\u003e34 x Adaptors for Sanding Tools (20 x Small, 14 x Tall)\u003c\/p\u003e\u003cp\u003e3 x Adaptors for Miniature Grinding \u0026amp; Cutting Discs\u003c\/p\u003e\u003cp\u003e4 x Special Corundum Miniature Grinding Discs\u003c\/p\u003e\u003cp\u003e40 x Miniature Cutting Discs\u003c\/p\u003e\u003cp\u003e14 x Miniature Felt Polishing Discs (11 x Flat, 3 x Long)\u003c\/p\u003e\u003cp\u003e46 x Round Sanding Papers\u003c\/p\u003e\u003cp\u003e6 x HSS Drill Bits\u003c\/p\u003e\u003cp\u003eSpecifications:\u003c\/p\u003e\u003cp\u003eInput Power: 135 Watt\u003c\/p\u003e\u003cp\u003eNo Load Speed: 10,000-35,000\/min\u003c\/p\u003e\u003cp\u003eLength: 340mm\u003c\/p\u003e\u003cp\u003eWeight: 0.67kg\u003c\/p\u003e","brand":"Einhell","offers":[{"title":"Default Title","offer_id":54255612920155,"sku":"114806","price":44.0,"currency_code":"EUR","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0962\/0652\/0667\/files\/114806_xl.jpg?v=1791242018","url":"https:\/\/www.axminstertools.com\/products\/einhell-tc-mg135e-grinding-engraving-tool-kit-230v","provider":"Axminster Tools","version":"1.0","type":"link"}
