The Einhell TC-VC 1820S Wet & Dry Vacuum is a versatile, powerful, all-round vacuum for simple wet and dry cleaning. It features an easy-to-clean stainless steel tank which has a capacity of 20 litres for devouring coarse or fine, wet or dry dirt and even liquids. It has a powerful motor to provide a poweful suction power and enough pressure to a blow connector for the user-friendly blow-cleaning of inaccessible areas.
It is fitted with a foam filter protecting the motor against soiling during wet vacuuming. Also has a float switch which interrupts the suction power automatically when the maximum level is reached, holders for the cable and accessories which enable all parts to be stored away quickly and neatly. With a carry-handle and four smooth-running castors for easy transportation.
Supplied with: 1 x 36mm Suction Hose, 1 x Three-Piece Plastic Suction Pipe, 1 x Large Suction Nozzle with Combination Insert for Carpets & Smooth Flooring and 1 x Crevice Nozzle.
Specifications:
Input Power: 1,250 Watt.
Capacity: Wet/Dry: 20 Litre.
Suction Hose Length: 1,500mm.
Suction Hose Diameter: 36mm.
Max Suction Power: 18 kPa.
Weight: 4.22kg.
Corded or Cordless Corded
Cable Length 3 m
Max Capacity Dry 20 Litre
Sound Pressure Level LpA [Uncertainty K] 78 dB(A)
Motor Power 1,250 W
Web Attribute Set Vacuum Cleaners - Wet & Dry
EAN Barcode 4006825585162
