{"product_id":"einhell-te-bf-18-li-belt-file-18v-body-only","title":"Einhell TE-BF 18 Li Belt File 18V (Body Only)","description":"\u003cp\u003eThe Einhell TE-BF 18 Li-solo Power X-Change Belt File is a practical, handy tool for grinding and deburring hard-to-reach areas. The narrower 9mm grinding arm is perfect for tight spaces and for grinding very small, intricate work pieces. With the wider 13mm grinding arm, even larger, flat surfaces can be tackled. The grinding arm can be pivoted by up to 90°, which gives the flexibility to work from various positions and makes it easier to machine hard-to-reach areas.\u003c\/p\u003e\u003cp\u003eThe speed regulator allows the sanding belt speed to be adjusted between 250 and 1,700 m\/min, so it can be tailored to the work piece at hand and the desired material removal rate. This means the tool can adapt to wide variety of materials. For more time-consuming work, the handy and lightweight cordless band file has a lock-on button.\u003c\/p\u003e\u003cp\u003eThe sanding belt can be changed via a tool-free, lever-operated mechanism, and the belt tracking is adjusted by a screw on the sanding arm. Thanks to its ergonomic design with Softgrip surfaces, the band file sits comfortably in the hand. The rugged motor housing has a Softgrip cover so it can be used as an auxiliary handle for easy handling. The grinding arm casing is made of solid metal.\u003c\/p\u003e\u003cp\u003eSupplied with: 2 x Grinding Arms, 6 x Sanding Belts 457 x 9mm (P60, P80 \u0026amp; P120 grit), 6 x Sanding Belts 457 x 13mm (P60, P80 \u0026amp; P120 grit), 1 x Suction Adaptor and 1 x Storage Pouch.\u003c\/p\u003e\u003cp\u003ePart of the Power X-Change series of tools, 3 Year Einhell Warranty, registration within 30 days required\u003c\/p\u003e\u003cp\u003eSupplied as body only (no battery or charger).\u003c\/p\u003e\u003cp\u003eSpecifications:\u003c\/p\u003e\u003cp\u003eSanding Belt Speed: 1,700m\/min.\u003c\/p\u003e\u003cp\u003eSanding Belt Length: 457mm.\u003c\/p\u003e\u003cp\u003eSanding Belt Width: 9mm or 13mm.\u003c\/p\u003e\u003cp\u003eGrip Diameter: 40mm.\u003c\/p\u003e\u003cp\u003eSuction Connection: Ø 35mm.\u003c\/p\u003e\u003cp\u003eWeight: 1.13kg.\u003c\/p\u003e","brand":"Einhell","offers":[{"title":"Default Title","offer_id":54118774505819,"sku":"113555","price":79.98,"currency_code":"GBP","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0962\/0652\/0667\/files\/113555_xl.jpg?v=1789791244","url":"https:\/\/www.axminstertools.com\/products\/einhell-te-bf-18-li-belt-file-18v-body-only","provider":"Axminster Tools","version":"1.0","type":"link"}
