The Einhell TE-BF 18 Li-solo Power X-Change Belt File is a practical, handy tool for grinding and deburring hard-to-reach areas. The narrower 9mm grinding arm is perfect for tight spaces and for grinding very small, intricate work pieces. With the wider 13mm grinding arm, even larger, flat surfaces can be tackled. The grinding arm can be pivoted by up to 90°, which gives the flexibility to work from various positions and makes it easier to machine hard-to-reach areas.
The speed regulator allows the sanding belt speed to be adjusted between 250 and 1,700 m/min, so it can be tailored to the work piece at hand and the desired material removal rate. This means the tool can adapt to wide variety of materials. For more time-consuming work, the handy and lightweight cordless band file has a lock-on button.
The sanding belt can be changed via a tool-free, lever-operated mechanism, and the belt tracking is adjusted by a screw on the sanding arm. Thanks to its ergonomic design with Softgrip surfaces, the band file sits comfortably in the hand. The rugged motor housing has a Softgrip cover so it can be used as an auxiliary handle for easy handling. The grinding arm casing is made of solid metal.
Supplied with: 2 x Grinding Arms, 6 x Sanding Belts 457 x 9mm (P60, P80 & P120 grit), 6 x Sanding Belts 457 x 13mm (P60, P80 & P120 grit), 1 x Suction Adaptor and 1 x Storage Pouch.
Part of the Power X-Change series of tools, 3 Year Einhell Warranty, registration within 30 days required
Supplied as body only (no battery or charger).
Specifications:
Sanding Belt Speed: 1,700m/min.
Sanding Belt Length: 457mm.
Sanding Belt Width: 9mm or 13mm.
Grip Diameter: 40mm.
Suction Connection: Ø 35mm.
Weight: 1.13kg.
Battery Voltage 18 V
Belt Speed 1,700 m/min
Sound Power Level LwA [Uncertainty K] 93.7 dB(A) [3.0 dB]
Battery Type Li-ion
Corded or Cordless Cordless
Abrasive Belt Size 457 mm x 9 mm or 13mm
Sound Pressure Level LpA [Uncertainty K] 85.7 dB(A) [3.0 dB]
Vibration Sanding [Uncertainty K] 2.6 m/s² [1.5 m/s²]
Web Attribute Set Cordless Sanders
EAN Barcode 4006825670974
