{"product_id":"einhell-te-os-18-113-li-palm-sander-18v-body-only","title":"Einhell TE-OS 18\/113 Li Palm Sander 18V (Body Only)","description":"\u003cp\u003eThe Einhell TE-OS 18\/113 Li-Solo Power X-Change Palm Sander is ideal for sanding flat surfaces made of wood and wood-based materials and, for example, abrades paint or varnish in no time. The on\/off switch is dust-proof. Its compact design with softgrip surfaces ensures comfortable use and optimal guidance of the orbital sander.\u003c\/p\u003e\u003cp\u003eThe sandpaper can be exchanged quickly with the help of hook-and-loop fastening and fixed without wrinkles. A clamping device is also integrated for attaching standard sandpaper. To keep the work area clean, the orbital sander has an integrated dust extraction system with dust collection box and removable pleated filter. Alternatively, an external suction system, for example an Einhell wet\/dry vacuum cleaner, can also be attached to the extraction connection.\u003c\/p\u003e\u003cp\u003eSupplied with an already mounted sanding plate (101 x 113mm) and 2 x Sandpaper (P120).\u003c\/p\u003e\u003cp\u003ePowered by Lithium-ion rechargeable batteries with a battery management system for a long life.\u003c\/p\u003e\u003cp\u003ePart of the Power X-Change series of tools, 3 Year Einhell Warranty, registration within 30 days required\u003c\/p\u003e\u003cp\u003eSupplied as body only (no battery or charger).\u003c\/p\u003e\u003cp\u003eSpecifications:\u003c\/p\u003e\u003cp\u003eOscillating Speed: 22,000\/min.\u003c\/p\u003e\u003cp\u003ePaper Size: 113 x 101mm.\u003c\/p\u003e\u003cp\u003eOscillating Circuit: 1.8mm.\u003c\/p\u003e\u003cp\u003eWeight: 1.03kg.\u003c\/p\u003e","brand":"Einhell","offers":[{"title":"Default Title","offer_id":54118774604123,"sku":"113557","price":49.98,"currency_code":"GBP","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0962\/0652\/0667\/files\/113557_xl.jpg?v=1789791260","url":"https:\/\/www.axminstertools.com\/products\/einhell-te-os-18-113-li-palm-sander-18v-body-only","provider":"Axminster Tools","version":"1.0","type":"link"}
