{"product_id":"einhell-te-os-18-150-li-corner-sander-18v-body-only","title":"Einhell TE-OS 18\/150 Li Corner Sander 18V (Body Only)","description":"\u003cp\u003eThe Einhell TE-OS 18\/150 Li Solo Power X-Change Sander utilises 'Extreme Fix' hook \u0026amp; loop fastening so that the abrasive paper can be changed in seconds and then deliver a high rate of material removal due to low slippage.\u003c\/p\u003e\u003cp\u003eFor clean, practically dust-free working, there is a dust collection box with active dust extraction. The collection box can be replaced by an attachment to a vacuum cleaner, drawing off the dust directly, this way the air remains clean and the abrasive paper sharp. The rugged aluminium fan impeller ensures that the sander runs smoothly to deliver optimum results.\u003c\/p\u003e\u003cp\u003eSupplied with 6 x Abrasive Sheets for wood so you can begin work immediately.\u003c\/p\u003e\u003cp\u003ePart of the Power X-Change series of tools, 3 Year Einhell Warranty, registration within 30 days required.\u003c\/p\u003e\u003cp\u003eSupplied as body only (no battery or charger).\u003c\/p\u003e\u003cp\u003eSpecifications:\u003c\/p\u003e\u003cp\u003eOscillating Speed: 24,000\/min.\u003c\/p\u003e\u003cp\u003eOscillating Diameter: 1.6mm.\u003c\/p\u003e\u003cp\u003eSanding Paper Size: 150 x 150 x 100mm.\u003c\/p\u003e\u003cp\u003eWeight: 0.748kg (without battery).\u003c\/p\u003e\u003cp\u003ePlease note; with the dust box fitted only 1.5Ah, 2.6Ah and Plus batteries can be used.  Standard Power X (PXC) batteries will need to be used without the dust box fitted.\u003c\/p\u003e","brand":"Einhell","offers":[{"title":"Default Title","offer_id":54118774473051,"sku":"113554","price":33.98,"currency_code":"GBP","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0962\/0652\/0667\/files\/113554_xl.jpg?v=1789791236","url":"https:\/\/www.axminstertools.com\/products\/einhell-te-os-18-150-li-corner-sander-18v-body-only","provider":"Axminster Tools","version":"1.0","type":"link"}
