The Einhell TE-PL 18/82 Li - Solo Planer has large knife shafts and a solid aluminium soleplate to provide optimum, flat results. The soleplate has a V-shaped groove for easy chamfering. There is also an automatic parking rest to protect both the planer and the workpiece. Its ergonomic, soft grip handle ensures tireless and comfortable operation.
Supplied with: 1 x Parallel Guide, 1 x Rebate Depth & 1 x TCT Planing Knife.
Part of the Power X-Change series of tools, 3 Year Einhell Warranty, registration within 30 days required
Powered by Lithium-ion rechargeable batteries with a battery management system for a long-life.
2.5Ah batteries or higher are recommended for best results.
Supplied as body only (no battery or charger).
Specifications:
Cutting Depth: 2mm, Rebate Depth: 8mm.
Planer Width: 82mm.
Weight: 2.44kg.
Battery Voltage 18 V
Sound Power Level LwA [Uncertainty K] 88.1 dB(A) [3.0 dB]
Battery Type Li-ion
Corded or Cordless Cordless
Sound Pressure Level LpA [Uncertainty K] 77.1 dB(A) [3.0 dB]
Vibration Cutting Wood [Uncertainty K] 2.93 m/s [1.5 m/s²]
Web Attribute Set Cordless Planers
EAN Barcode 4006825645934
