{"product_id":"einhell-te-ps-165-plunge-saw-1-200w-230v","title":"Einhell TE-PS 165 Plunge Saw 1,200W 230V","description":"\u003cp\u003eThe Einhell TE-PS 165 Plunge Saw is easy to use, sawing depth and tilt angle adjustment are performed without tools. Enables precise cuts to be made at tilt angles of 45° to 90°. Straight results are assured by the parallel stop and a blade lock makes it easy to change the saw blade.\u003c\/p\u003e\u003cp\u003eA large handle helps prevent fatigue when working. Whilst the vision panel provides a better view of the cutting area. Fitted with a four meter cable for an extra large radius of operation. There is also a handy vacuum extractor adaptor that helps you to keep the work space clean whilst you work.\u003c\/p\u003e\u003cp\u003eSupplied with: 1 x High Quality HW\/TCT Saw Blade 165 x 20mm x 48T.\u003c\/p\u003e\u003cp\u003eGuide rail system is available separately.\u003c\/p\u003e\u003cp\u003eSpecifications:\u003c\/p\u003e\u003cp\u003eInput Power: 1,200W.\u003c\/p\u003e\u003cp\u003eNo Load Speed: 5,200\/min.\u003c\/p\u003e\u003cp\u003eDepth of Cut: @90º 56mm, @45º 42mm.\u003c\/p\u003e\u003cp\u003eBlade: 165 x 20mm Bore.\u003c\/p\u003e\u003cp\u003eWeight: 4.75kg.\u003c\/p\u003e","brand":"Einhell","offers":[{"title":"Default Title","offer_id":54118776013147,"sku":"113544","price":88.98,"currency_code":"GBP","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0962\/0652\/0667\/files\/113544_xl.jpg?v=1789791346","url":"https:\/\/www.axminstertools.com\/products\/einhell-te-ps-165-plunge-saw-1-200w-230v","provider":"Axminster Tools","version":"1.0","type":"link"}
