Einhell
Einhell TE-TC 18/115 Li Tile Cutter 18V (Body Only)
SKU: 113546
£86.70
£72.25 Excl. VAT
  • Cordless & lightweight for easy portability
  • Tilting table (0-45°) with adjustable stops for precise cuts
  • Integrated water container for cooling & cutting wheel guard for safety
  • Non-slip, low-vibration feet for stability & secure positioning
  • Includes diamond cutting disc & blade change tool, but no battery or charger
  • Part of the Power X-Change series of tools
  • 3 Year Einhell Warranty (registration required)
The Einhell TE-TC 18/115 Li-Solo Cordless Tile Cutter can be used anywhere, thanks to its battery power source (NOT supplied) and low weight design. The table can be tilted from 0° to 45°. It also features a parallel stop with angle scale for exact straight cuts and an adjustable angle stop with settings from -45° to +45° for mitre cuts.
An integrated water container provides cooling for the cutting disc, and for safety there is a cutting wheel guard. Non-slip, low-vibration feet ensure a secure and steady standing position, and a carrying option for easy transport.
Powered by Lithium-ion rechargeable batteries with a battery management system for a long-life.
Part of the Power X-Change series of tools, 3 Year Einhell Warranty, registration within 30 days required
Supplied with: 1 x Diamond Cutting Disc & 1 x Blade Change Tool.
Supplied as body only (no battery or charger).
Specifications:
No Load Speed: 3,800/min.
Cutting Height: @45° 16mm, @90° 24mm.
Cutting Disc: Ø 115 x 22.2mm Bore.
Table Tilt: 0-45°.
Working Table Size: 305 x 335mm.
IP Class: IPX0.
Weight: 3.5kg.
Battery Voltage 18 V
Battery Type Li-ion
Corded or Cordless Cordless
Web Attribute Set Cordless Hacksaw/Bandsaw
EAN Barcode 4006825657500
