The Einhell TP-AP 18/28 Li BL - Solo Brushless Reciprocating Saw offers more power and runs for longer. Its anti-vibration function ensures low vibration while working. A soft grip handle and gripping surfaces make the saw easy and comfortable to handle. An adjustable soleplate enables optimal use of the blade, and tool-less blade changes keep things simple.
Supplied with: 1 x KWB Wood Blade.
Part of the Power X-Change series of tools, 3 Year Einhell Warranty, registration within 30 days required.
Powered by Lithium-ion rechargeable batteries with a battery management system for a long-life.
2.5Ah batteries or higher are recommended for best results.
Supplied as body only (no battery or charger).
Specifications:
Strokes at No Load: 0-2,500/min.
Stroke Length: 28mm.
Cutting Depth: Wood 200mm, Plastic 20mm, Steel 12mm.
Weight: 2.06kg.
