The Einhell TP-CI 18/220 Li BL-Solo Power X-Change Impact Driver is powered by an Einhell PurePOWER brushless motor. This brushless motor offers more power and a longer running time than conventional carbon brush motors. Once you register online, the brushless motor has a 10-year warranty. Tightening long screws with large diameters takes no effort at all with the cordless impact driver. The impact driver features a 1/4 (6.35 mm) hexagonal chuck and provides 220Nm of torque.
The finely adjustable speed control electronics can be used to adapt the tool to the material at hand, so both the material and the impact driver itself are not subjected to excessive stress. In particular, soft and delicate materials can be handled gently. The short, lightweight design with ergonomic Softgrip surfaces ensures the tool can be held comfortably and firmly.
Powered by Lithium-ion rechargeable batteries with a battery management system for a long life.
Part of the Power X-Change series of tools, 3 Year Einhell Warranty, registration within 30 days required.
Supplied as body only (no battery or charger).
Specifications:
Bit Holder: 1/4 (6.35mm)
No Load Speed: 0-2,900/min.
Max. Fastening Torque: 220Nm.
Weight: 1.16kg.
Battery Voltage 18 V
Reverse No
Sound Power Level LwA [Uncertainty K] 89.7 dB(A) [3.0 dB]
Battery Type Li-ion
Corded or Cordless Cordless
Sound Pressure Level LpA [Uncertainty K] 81.7 dB(A) [3.0 dB]
Web Attribute Set Cordless Impact Drivers
EAN Barcode 4006825675146
