{"product_id":"einhell-tp-ci18-220li-impact-driver-4-0ah-battery-charger-case","title":"Einhell TP-CI18\/220Li Impact Driver 4.0Ah Battery, Charger \u0026 Case","description":"\u003cp\u003eThe Einhell TP‑CI 18\/220 Li BL‑Solo Impact Driver delivers powerful, efficient performance for demanding screwdriving tasks. Its PurePOWER brushless motor provides increased power, longer runtime and enhanced durability compared to traditional carbon‑brush motors. Register online to activate the 10‑year motor warranty.\u003c\/p\u003e\u003cp\u003eProducing 220 Nm of torque, the impact driver makes tightening long or large‑diameter screws effortless. The 1\/4\u003cspecial id=\"32\"\u003e\u003c\/special\u003e (6.35 mm) hex chuck enables quick bit changes, while variable speed control lets you match the tool to the material—ideal for protecting softer or delicate surfaces. The compact, lightweight design and Softgrip ergonomic surfaces ensure comfortable handling, even during extended use.\u003c\/p\u003e\u003cp\u003eAs part of the Power X‑Change family, the tool is compatible with every PXC battery. Includes a 3‑year Einhell warranty with registration within 30 days.\u003c\/p\u003e\u003cp\u003eSpecifications\u003c\/p\u003e\u003cp\u003e\u003cspecial id=\"14\"\u003e\u003c\/special\u003e Bit Holder: 1\/4\u003cspecial id=\"32\"\u003e\u003c\/special\u003e (6.35 mm)\u003c\/p\u003e\u003cp\u003e\u003cspecial id=\"14\"\u003e\u003c\/special\u003e No Load Speed: 0–2,900\/min\u003c\/p\u003e\u003cp\u003e\u003cspecial id=\"14\"\u003e\u003c\/special\u003e Max Torque: 220 Nm\u003c\/p\u003e\u003cp\u003e\u003cspecial id=\"14\"\u003e\u003c\/special\u003e Weight: 1.16 kg\u003c\/p\u003e\u003cp\u003eThe high‑capacity battery features Einhell’s 7‑in‑1 ABS Active Battery Management System, a 3‑stage LED charge indicator and an intelligent microprocessor that monitors temperature and voltage. A repair mode can reactivate deeply discharged cells. Premium lithium‑ion technology minimises self‑discharge, while the rubber‑coated housing offers excellent impact resistance. A recessed ergonomic handle ensures secure, comfortable handling.\u003c\/p\u003e\u003cp\u003eThe compact, wall‑mountable 3A charger offers fast charging with intelligent battery monitoring for maximum safety and reliability. A refresh mode restores deeply discharged batteries, and a 6‑stage LED display provides clear charging status at a glance.\u003c\/p\u003e\u003cp\u003eThe Einhell E‑Case S‑F provides safe, convenient storage and transport for tools and accessories. As part of the modular, stackable E‑Case system, it offers flexible organisation for equipment and consumables. Measuring 44 × 33 × 13 cm and supporting loads up to 25 kg, it is ideal for both workshop and on‑site use.\u003c\/p\u003e\u003cp\u003eA secure locking mechanism allows multiple cases to be connected firmly, and its clever design means the case can be opened even while stacked. Made from durable polypropylene, it is splash‑proof, heat‑resistant and impact‑resistant. Two foldable ergonomic handles ensure comfortable carrying, while an integrated locking point allows the case to be secured with a standard padlock.\u003c\/p\u003e\u003cp\u003eSupplied with a 18V 4.0Ah Power X‑Change Li‑Ion Battery, 3A Quick Charger and E‑Case S‑F.\u003c\/p\u003e","brand":"Einhell","offers":[{"title":"Default Title","offer_id":54118842335579,"sku":"114147","price":126.98,"currency_code":"GBP","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0962\/0652\/0667\/files\/114147_xl.jpg?v=1789793164","url":"https:\/\/www.axminstertools.com\/products\/einhell-tp-ci18-220li-impact-driver-4-0ah-battery-charger-case","provider":"Axminster Tools","version":"1.0","type":"link"}
