{"product_id":"einhell-tp-mg-18-li-bl-multi-tool-18v-body-only","title":"Einhell TP-MG 18 Li BL Multi Tool 18V (Body Only)","description":"\u003cp\u003eThe Einhell TP-MG 18 Li BL-Solo Power X-Change Multifunctional Tool is a versatile and high-quality device for construction and renovation work. Thanks to its extensive equipment, tasks such as sawing, sanding or scraping can be carried out effortlessly. Powered by a Einhell PurePOWER brushless motor. This brushless motor offers more power and a longer running time than conventional carbon brush motors. Once you register online, the brushless motor has a 10-year warranty.\u003c\/p\u003e\u003cp\u003eSpeed electronics ensure precise and material-friendly working. The multitool works with an oscillation angle of 3.2°, which enables precise use. A switch with locking function facilitates time-intensive work. The innovative, vibration-decoupled device head enables vibration-free application. Whilst softgrip surfaces ensure safe and comfortable working.\u003c\/p\u003e\u003cp\u003eThe tool-free accessory change is made possible by the quick-release lock. Thanks to the magnetic tool adapter, accessories can be changed quickly and easily. The 12-pin tool adapter allows flexible positioning of accessories.  It also features an LED light that ensures that the working area is perfectly lit.\u003c\/p\u003e\u003cp\u003ePart of the Power X-Change family. Powered by Lithium-ion rechargeable batteries with a battery management system for a long life.\u003c\/p\u003e\u003cp\u003eSupplied with: 1 x Delta Sanding Shoe with Velcro Fastener, 1 x Diamond Segment Saw Blade for tile joints, 1 x Segment HSS Saw Blade for wood, plastic and soft metal, 1 x BIM Plunge Cut Saw Blade for metal and 1 x HCS Plunge Cut Saw Blade for wood and plastic.\u003c\/p\u003e\u003cp\u003ePart of the Power X-Change series of tools, 3 Year Einhell Warranty, registration within 30 days required.\u003c\/p\u003e\u003cp\u003eSupplied as body only (no battery or charger).\u003c\/p\u003e\u003cp\u003eSpecifications:\u003c\/p\u003e\u003cp\u003eOscillating Speed: 22,000 - 40,000\/min.\u003c\/p\u003e\u003cp\u003eNo Load Speed: 11,000 - 20,000\/min.\u003c\/p\u003e\u003cp\u003eAngle of Oscillation: 3.2°.\u003c\/p\u003e\u003cp\u003eSandpaper Size: 93 x 93 x 93mm.\u003c\/p\u003e\u003cp\u003eWeight: 1.08kg.\u003c\/p\u003e","brand":"Einhell","offers":[{"title":"Default Title","offer_id":54118748553563,"sku":"113540","price":99.98,"currency_code":"GBP","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0962\/0652\/0667\/files\/113540_xl.jpg?v=1789791144","url":"https:\/\/www.axminstertools.com\/products\/einhell-tp-mg-18-li-bl-multi-tool-18v-body-only","provider":"Axminster Tools","version":"1.0","type":"link"}
