The Einhell TP-MG 18 Li BL-Solo Power X-Change Multifunctional Tool is a versatile and high-quality device for construction and renovation work. Thanks to its extensive equipment, tasks such as sawing, sanding or scraping can be carried out effortlessly. Powered by a Einhell PurePOWER brushless motor. This brushless motor offers more power and a longer running time than conventional carbon brush motors. Once you register online, the brushless motor has a 10-year warranty.
Speed electronics ensure precise and material-friendly working. The multitool works with an oscillation angle of 3.2°, which enables precise use. A switch with locking function facilitates time-intensive work. The innovative, vibration-decoupled device head enables vibration-free application. Whilst softgrip surfaces ensure safe and comfortable working.
The tool-free accessory change is made possible by the quick-release lock. Thanks to the magnetic tool adapter, accessories can be changed quickly and easily. The 12-pin tool adapter allows flexible positioning of accessories. It also features an LED light that ensures that the working area is perfectly lit.
Part of the Power X-Change family. Powered by Lithium-ion rechargeable batteries with a battery management system for a long life.
Supplied with: 1 x Delta Sanding Shoe with Velcro Fastener, 1 x Diamond Segment Saw Blade for tile joints, 1 x Segment HSS Saw Blade for wood, plastic and soft metal, 1 x BIM Plunge Cut Saw Blade for metal and 1 x HCS Plunge Cut Saw Blade for wood and plastic.
Part of the Power X-Change series of tools, 3 Year Einhell Warranty, registration within 30 days required.
Supplied as body only (no battery or charger).
Specifications:
Oscillating Speed: 22,000 - 40,000/min.
No Load Speed: 11,000 - 20,000/min.
Angle of Oscillation: 3.2°.
Sandpaper Size: 93 x 93 x 93mm.
Weight: 1.08kg.
Battery Voltage 18 V
Sound Power Level LwA [Uncertainty K] 87 dB(A) [3.0 dB]
Battery Type Li-ion
Corded or Cordless Cordless
Sound Pressure Level LpA [Uncertainty K] 79 dB(A) [3.0 dB]
Web Attribute Set Cordless Oscillating Tools
EAN Barcode 4006825672060
