{"product_id":"einhell-tp-ps-18-165-li-bl-plunge-saw-18v-body-only","title":"Einhell TP-PS 18\/165 Li BL Plunge Saw 18V (Body Only)","description":"\u003cp\u003eThe Einhell TP-PS 18\/165 Li BL PROFESSIONAL is a versatile plunge cut saw designed for precision and performance in any workshop. Ideal for cutting wood, panels, and plastics, its plunge function allows you to start cuts directly from the surface.\u003c\/p\u003e\u003cp\u003ePowered by an advanced Einhell Brushless Motor, it delivers greater power, extended runtime, and reduced maintenance compared to conventional carbon brush motors. Plus, register online to enjoy a 10-year motor warranty. Safety features include soft start, motor brake, and restart protection for secure operation.\u003c\/p\u003e\u003cp\u003eThe saw features a lightweight, compact design with a premium aluminium table for accurate, straight cuts when paired with the parallel stop. A viewing window and cutting line indicator ensure precise alignment, while a spindle lock makes blade changes quick and easy.\u003c\/p\u003e\u003cp\u003eFor comfort, the saw includes an ergonomic main and front handle with soft-grip surfaces for fatigue-free use. Both cutting depth and tilt angle are easily adjustable without tools. The high-quality carbide blade (Ø165 mm) cuts up to 56 mm at 90° (without guide rail) and delivers clean, edge-close results. A swiveling dust extraction port keeps your workspace tidy, and the saw is fully compatible with the Einhell guide rail system.\u003c\/p\u003e\u003cp\u003ePart of the Power X-Change family, this tool uses lithium-ion batteries with advanced battery management for long-lasting performance.\u003c\/p\u003e\u003cp\u003eSpecifications:\u003c\/p\u003e\u003cp\u003eNo Load Speed: 5,000\/min.\u003c\/p\u003e\u003cp\u003eMax. Cutting Depth @90º 56mm, @45° 42mm\u003c\/p\u003e\u003cp\u003eBlade: 165mm, 20mm Bore\u003c\/p\u003e\u003cp\u003eBevel Capacity: 57°\u003c\/p\u003e\u003cp\u003eSuction Connection Diameter: 36mm\u003c\/p\u003e\u003cp\u003eWeight: 4.23kg\u003c\/p\u003e","brand":"Einhell","offers":[{"title":"Default Title","offer_id":54118837453147,"sku":"113894","price":168.98,"currency_code":"GBP","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0962\/0652\/0667\/files\/113894_xl.jpg?v=1789792837","url":"https:\/\/www.axminstertools.com\/products\/einhell-tp-ps-18-165-li-bl-plunge-saw-18v-body-only","provider":"Axminster Tools","version":"1.0","type":"link"}
