The Einhell TP‑PS 18/165 Li BL PROFESSIONAL Plunge Saw delivers precise, powerful cutting performance for wood, panels, and plastics, making it ideal for fine carpentry, interior finishing, and accurate plunge cuts starting directly in the material. Its advanced Einhell Brushless Motor provides increased power, extended runtime, and reduced maintenance compared to traditional carbon brush motors, and offers a 10‑year motor warranty when registered online. Safety features including soft start, motor brake, and restart protection ensure controlled and reliable operation during every cut.
Designed for accuracy and ease of use, the saw features a lightweight, compact build with a high‑quality aluminium table for smooth, straight cutting, especially when paired with the parallel stop or the compatible Einhell guide rail system. A clear viewing window and cutting line indicator support precise alignment, while the spindle lock allows fast, straightforward blade changes. Both cutting depth and bevel angle can be adjusted without tools, offering quick setup and total flexibility. The included 165mm carbide blade provides clean, near‑edge cuts with a maximum depth of 56mm at 90° and 42mm at 45°. A swivelling dust extraction port helps maintain a cleaner working environment.
For comfortable, fatigue‑free operation, the plunge saw is equipped with ergonomic main and auxiliary handles with soft‑grip surfaces. As part of the Power X‑Change battery platform, the tool uses advanced lithium‑ion technology and intelligent battery management for long‑lasting, dependable performance.
The kit also includes an 18V 2.5Ah Power X‑Change battery and 4A Power X‑Fastcharger. The battery features a 7‑in‑1 ABS Active Battery Management System with microprocessor control for temperature, voltage, and battery health, and can even revive deeply discharged batteries using repair mode. High‑quality Li‑ion cells ensure minimal self‑discharge, while a rubber‑coated, impact‑resistant housing and recessed grip enhance durability and handling.
The fast charger reduces downtime with quick charging technology, continuously monitors battery condition for maximum safety, offers a refresh mode for exhausted batteries, and provides clear status updates via a 6‑stage LED indicator. Integrated wall‑mount eyelets allow convenient storage.
Battery Capacity 2.5 Ah
Battery Voltage 18 V
Max Depth of Cut @ 45º 42 mm
Max Depth of Cut @ 90º 56 mm
Blade Diameter 165 mm
Batteries Included 1
Battery Type Li-ion
Corded or Cordless Cordless
Saw Blade Speed 5,000 rpm
Web Attribute Set Cordless Circular Saws
EAN Barcode 5052511146529
